Question about Buffalo Technology TeraStation Home Server (HS-D1.0TGL/R5) (E171512)
New Fan for buffalo terastation ts-1.0tgl/r5
i'd like to replace the build-in fan in my buffalo terastation ts-1.0tgl/r5 for a more silent one.
its a 80*80*25mm fan with a three-pin connector. from what i heard, it has to be adjustable.
can i just buy a silent fan with a three-pin connector or do i have to make sure that it has certain properties?
thanks in advance,
alex
  • 24 Answers
Just the fan, with 3 wires, as long as it has the 3 wires then you can adjust the speed... most fans do come with this 3 wires setup now adays
Posted on Apr 18, 2009
Jetta compressor makes a noise as if the fan belt is finished but when I lubricate it it goes silent then later makes that whistling sound. What could be the problem? and It's a year now.
If you are talking about the fan it's self it could be one of three things.
Fan belt may be worn and needs replacing or if its new the belt may need to be tensioned again as new belts do stretch a bit. But while you are there check the rubber of the belt for cracking or perished area
Could be a noisy bearing that needs cleaning or replacing which will make a whistle type sound.
Last is that the actual fan may be out of shape or the fan housing which could have a build up of dirt dust that could give off a odd sound.
Hope this is of some help
Aug 09, 2013 | Cars & Trucks
Tip
Buffalo Terastation
No need to enter Username and password in vista everytime you boot the computer
you can blame the security setting in windows vista -these decide the request /response authentication protocol used for the network login .The default setting for win vista NTLMv2 (NT lan manager version 2)
but the terastation still uses an earlier version of it .
The setting can be changed as follows :click tge start button ,enter "secpol.msc " in the search field and double click the progrma found .confirm the start of the console with "continue' .Finally ,double- click and open "security settings".then expand the "local policies" "security option" folder .In the following list select "Network security :lan manager authentication level".A dialog box open on double clicking it .At this point,switch to the "local security setting" tabthe default set option "send NTLMv2 respone only " to "send LM & NTLM -use NTLMv2 session security.if negotiated " .save the changes with "ok" and teraStation will start working again
on Apr 24, 2010 | Computers & Internet
Buffalo 85 fan not blowing
sounds like the fan is not working, can you isolate the fan and run it by itself with out the burned, this will tell you if it's the fan motor or some sensor that's the trouble
Apr 28, 2013 | Heating & Cooling
Noise from fan in modem
Hi'
Normally dust gets caught up in the fan you can try blowing it out to free the dust or the bearings are getting worn and the fan needs to be replaced.
You can by silent fans for desk top pcs as well.
cheers
Nov 27, 2012 | Computers & Internet
Mac OSx 10.8 cannot search BUFFALO TS-8VH24TL/R6 24TB
Specs only indicate Windows. No iOS. Might be cause of the RAID configuration / software.
Though it does support HTTP and FTP protocols.
Nov 05, 2012 | Buffalo Technology - TS-8VH24TL/R6 -...
Bootmgr is missing
if you can get hold of a windows installation disc, you can boot from it and use the repair option.
Sep 21, 2012 | Buffalo Technology BUFFALO WS-6V12TL/R5...
How to install antivirus in Buffalo Tsx40tlr5 Terastation
You have antivirus installed on this NAS system? You will want to look up the product manual for that product and see if it allows antivirus programs to be installed. Some NAS stations come with built in anti virus. You could even contact their support to get a list of "SUPPORTED" anti virus software. At which point, you will have to telnet or console into the data storage system and install the software. You could probably install the files through a CIFS connection but it would be best to contact Buffalo support as they can walk you through the proper steps.
Aug 05, 2012 | Buffalo Technology Buffalo Tsx40tlr5...
I need to reset the IP address, subnet, etc, of my TeraStation 1.0TGL/R5, but I cant do with the nav tool on the computer. Is there any way to manually reset it? Thank You
click start run and type in cmd click ok when ms dos prompt up in that type ipconfig /renew then you will see the renewed ip address subnet mask etc
Apr 01, 2011 | Buffalo Technology TeraStation Pro...
Buffallo terastation
How can you loose the password? if your that stoopid then i think you shouldnt own TS,or is it you have bought second hand only to find its password encrypted? either way if you cant read then you shouldnt own a TS instead why not see if you can swap for an external HD ;D
Jan 25, 2009 | Buffalo Technology TeraStation Home...
Case coling fan is very loud
Hey there Ohio,
There are a few things that cause a normally silent fan to get noisy.
  • Dust building up - Unlikely, but check. Clean if necessary.
  • Some internal wiring brushing against the trailing edge of the fan blades - Likely only if the case was recently opened. Re-open and check, relocate the wiring if necessary.
  • The fan is getting ready to fail - Most likely. Replace the fan. If you have an unused computer, pull a fan out of that one to use. New fans are available for under $20.00 USD .
This replacement is very easy.
  1. Four screws out
  2. Unplug
  3. Remove old fan, put new one in.
  4. Plug in
  5. Four screws in
Don't wait until it fails, though. A cool computer is a happy computer.
Hope this helps,
Mike
Nov 28, 2008 | Computers & Internet
Buffalo Technology TeraStation  Home Server (HS-D1.0TGL/R5) (E171512) Logo
528 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
