Question about Asko D1776 Stainless Steel Built-in Dishwasher
F1 ERROR MY DISHES ARE CLEAN, BUT ALL WET
  • 234 Answers
This is a water heating error.
There are a few possible causes:
  1. Bad heating element
  2. Bad connection of wires to heating element
  3. Bad control board
Be sure that water hookup for dishwasher is hot water.
Unplug electrical connection to unit.
Remove front bottom cover.
Check wires to heating element for burning and that they are connected properly.
You may need a multimeter to check power to element and to help trace the circuit if necessary.
Posted on Apr 15, 2009
Samsung DMS300TR dishwasher. The dishwasher error code is F5, it switches off before the cycle is complete. The dishes ain't clean and it seems as if the dishes are still greasy.
Please see this page I found in the owner's manual for your machine. Error codes F1 to F8 (except F2) require you to unplug the power and turn off the water supply before requesting service, so this will require a professional service person.
Oct 01, 2015 | Samsung Dishwashers
Why are dishes wet when cycle completed?
The appliance repair man attempted to solve all problems by replacing the control board. He may have overlooked a defective heater for drying the dishes.
Sep 03, 2015 | Dishwashers
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
HE2, 110.46462500, f1 error signal, clothes sopping wet, no high spin, add a garment only lit up. What can we do to fix it. Husband works on appliances. Drain is clean and pump is working.
Hello
F1 is a communication failure related to the circuit board.You may be able to check for any loose connections at the main board if possible.
Maybe,unplug unit for 5 min then plug back in.
More then likely your main board is bad.A sevice tech will be needed.
Apr 01, 2011 | Kenmore HE2 Plus Front Load Washer
Hi I have a F1 error code on my dishwasher. It is a two drawer model.
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 18, 2011 | Dishwashers
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
Jan 21, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
I have a similar problem to another person. The drain on the dish drawer was blocked. The unit now shows an F1 error code ( flood?) and the pump runs continuously even after I've unblocked everything. I've...
the flood sensor on this unit is a PC board in the base, so you would need to remove the lower drawer and dry it out under there. If the base is dry and you still have the error, you can take a look at that sensor and clean any corrosion/minerals off. Generally cleaning it doesnt work and that little board needs replacement, but you may get lucky.
Apr 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Clean dishes are wet
1)please check the rinse chemical passing correctly.
2)check the boiler heater working.
Jan 08, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Asko D1776 Stainless Steel Built-in Dishwasher Logo
248 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
