Question about HP PSC 2210 All-In-One InkJet Printer
Error: 0x887dd03a My All in One display gives me a blue screen with this message. I've done a semi-full reset with no success. HP is no help. Anyone with any insights? Thanks.
  • scaler123 Jan 31, 2008
    Having the same problem, I've pretty much narrowed it down to iTunes, at least in my case.
  • 432 Answers
Uninstall all software and drivers related to this printer. After rebooting the pc, Insert the installation CD again. After it starts up and you get to the point where the software wants to install in a directory, ie..c:\program files\HP\.... STOP. Reinstall the software in another directory. C:\HP\PSC2210. let it go thru the entire setup and reboot. Make sure the printer is unplugged before installing software. The software will let you know when to plug the printer in. I hope this helps.
Posted on Sep 21, 2007
Ink system failed. error message Oxc18A0001. Turn power off then on again Have done this but message still reappears
Please perform the below resets
1.
Press & hold the power button > unplug the power cable from the back of the printer while holding the button for 30 seconds > plug the cable back then release the button.
2.A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Oct 04, 2010 | HP Photosmart C6280 Printer
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
States scanner failer; turn off ;then on; have
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
      NOTE: Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the productFollow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 26, 2010 | HP OfficeJet 7410 All-In-One InkJet...
After replacing color cartridges I get the following message on my C6830 HP printer ''Enter special key combo''
try pressing buttons in sequence blue then green then grey it should take you to a special menu look for reset meni and select semi full reset if that does not work try removing the cartridges while machine on pull out power cord wait 15 seconds plug power back in insert cartridge when promted on display screen
Jan 26, 2010 | HP Office Equipment & Supplies
Error message 0x610000f6 won't re-set.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
Sep 28, 2009 | HP Photosmart Premium C309A All-In-One...
Status light blinking red
please follow the steps given below to power cycle and reset the product.
  2. Unplug the power cord from the product..
Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
May 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
HP C5180 "wrong cartridges" error
try this semi full reset
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
I have a HP 7410, every time I print I get three error messages. First one is "New HP Photo Print Cartridge successfully installed". Second one is "New HP Tricolor Photo Print Cartridge successfully...
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find the hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Let me know if this helps.
If it doesn't, I will research it further. If it does please rate it.
Joe
Nov 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
1,101 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
