Question about Ryobi Garden
Ryobi 705R Strimmer
I'm trying to get the bushing housing assembly apart. It has some twine caught in it and is not spinning free enough. I've got it apart to the retainer spring grip but can't seem to get that apart. Any suggestions? Is it a case of brute force?
  • grahameva Apr 15, 2009
    The Bushing Housing assembly is at the other end of the strimmer, not the engine. It is where the line fixes in. After taking the line out I'm trying to strip down the shaft and housing. I have the housing off the machine but it appears to be one assembly. However having looked up spare part suppliers who have exploded diagrams the assembly will apparently come apart. I just can't quite work out how?
  • 73 Answers
SOURCE: twine replacement
should be a bumper on the bottom, unscrew it and it comes off
Posted on May 25, 2009
canbruce75
  • 1776 Answers
SOURCE: Fuel line routing for RYOBI Models 705r and 725r
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Sep 08, 2009
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Posted on Sep 10, 2009
Testimonial: "Thanks. Got it."
rycgl
  • 1545 Answers
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Jul 10, 2010
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
Ryobi electric strimmer rbc 1000ex would not start
hi guys ,i have a ryobi electric rbc 1000ex and i've only used it about 5 times since new ,blue light comes on , but wount spin ? any ideas ?
May 12, 2012 | Garden
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
Ryobi 3043e strimmer
It could be fuel, carburetor, mixture OR the muffler may be clogged. If the muffler is clogged, the unit won't run at high throttle.
Steps: Remove the back housing to access the muffler. You may want to remove the gas tank to avoid a spill. Remove the muffler (2 large screws). Remove the muffler door (3 small screws). The screen should be cleaned using a pin (poke out any hardened material). Most important: The muffler door is 2 parts. Pry it apart and scrape off the burnt carbon that is clogging the exhaust path. Re-assemble and start.
May 03, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi 705r strimmer won't run !
The carburetor needs to be disassembled and cleaned with carb. cleaner. Or, it needs a new carburetor kit. If you need tips on how to do this, just let me know.
Jim
Jun 03, 2009 | Ryobi Garden
I have a ryobi weed eater and the twine locks up and wont release
There is really no solution to this problem -- it is inherent in weed **** -- I have extensive experience with this phenomenon, spending many hours trying dozens of approaches. If you need a **** my suggestion would be buy a new one -- it'll get you through a season or two...
Apr 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
Ryobi 2 cycle gas trimmer 705r/725r
Aug 28, 2008 | Ryobi Garden
How do I rethread the cutting line on a black and decker strimmer reflex plus
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Jul 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
152 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
