Question about Canon EOS-AE-1 35mm SLR Camera
Canon Ae-1 Installed battery and meter worked however the film advance does nothing and shutter button does nothing. Other that those problems everything else on the camera is in top shape for it's age. Any suggestions?
  • Anonymous Aug 08, 2008
    CANON AE-1 ADVANCE LEVER STUCK-MIRROR STUCK UP-IT COCKED & CLICKED LIKE TO SHOOT BUT DID GO THRU THE HOLE CYCEL. BATTERY DEPLACED DID NOT HELP
  • Anonymous Sep 13, 2008
    same exact thing. meter works, but shutter wont release. brand new battery, checked battery chamber and the bottom connector thing isnt stuck...
Hey, I ran into the same problem, and messing around today I found the electro-trip. The battery is dead, but when I fire the shutter manually, there's no lag between the two blades. Is this just because the battery has died? I fear the circuit that trips the shutter may also be blown. The one capacitor, or whatever the large solder bumps are, was severely corroded and so where some of the terminals. I tried cleaning them, and I'm not sure what else to do. I have no real attachment to this camera and it's been broken for 15 years, since my dad took it to the Galapagos. They're revolutionary, but I must say poorly built with their circuitry easily exposed to moisture on the bottom and the copper plated PVC parts.
Posted on Feb 14, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Shutter release magnet faulty ( your camera is cocked but since you cannot release the shutter you cannot wind the film ). Remedy : open bottom cover by removing the two screws. You will see two small electro magnets one on the left hand side and the shutter release one on the right hand side ( it is the bigger one of the two ). The very thin wires from the magnet to the small circuit board on the right hand side may be broken : inspect and resolder 10 joints you see on the p.c. board. If no joy replace the s.r.magnet.
Posted on Sep 16, 2007
SOURCE:
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
The shutter wont work and the light meter doesn't move, also it wont advance the film. what could be wrong? I'm hoping it's the battery...
There is a large circular cover on the bottom of the camera. Inside is a button battery. Yours is dead and should be replaced with one of the same I.D.number.
Sep 26, 2009 | Canon EOS-AE-1 35mm SLR Camera
Just purchased from an auction. the film advance
The first to check is the battery condition. Press the battery check button on the top cover and see where the meter needle rests in the VF. If the needle is above 5.6, battery is getting weak and it will cause irratic shutter release or no release. It's time to change the battery. If needle is below 5.6, then you have magnet problem or other fault. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 31, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 program film advance locked
The cost of fixing is almost the same as buying a used or refurbished AE-1 about $80-120
Dec 21, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
When we advance film, it takes a picture
The problem is usually caused by a dirty release magnet. I can tell you how to fix it if you are handy with small tools
Feb 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
AE-1Problems... Advance lever, Shutter, and more.
This happened to me to both the Canon's I had. I found out it was a dead battery. Once I replaced those it worked fine. The battery is hidden under the hand grip which can be taken off using a coin in the screw slot.
Sincerely,
Karin
Jul 31, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
782 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
