Question about Pyle PT-2000 Amplifier
Replacement parts for Pyle power amp PT-2000
I have a Pyle Pt-2000 power amp. the amp works great, however one of the Vu meters (power meters) does not illuminate. I need to find a replacement but cannot get through on the contact info of the Pyle website? any ideas where to get replacement parts?
  • Pyle Master
  • 5,126 Answers
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Posted on May 27, 2009
Why is my pyle pro pt 2000 burning the fuses
When using this type of amplifier, especially to run subwoofers, you need to use a capacitor of at least 1F in value across the power input. Large capacitors counteract the effect of voltage drops caused by audio program elements such as heavy kick drum beats or other low-frequency spurious elements, and can save your car alternator from being damaged as well.
May 19, 2015 | Pyle Car Audio & Video
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
PyLE PT2000 Power Amplifier' { is it worth it??}
People talk alot of **** about Pyle amps, all I can say is that,
I have two PT-2000 & PT-1800 power amps that I have set in bridge mode, one for each speaker and they are powering two Altec-Lansing 18" inch subs, one amp per speaker, no hiss, line noise or anything and the system kicks. I tried the Pyles on a whim because I got tired the trouble I was having with the QSC and Crown power amps, could not go a year without having something go wrong always sending back to dealer for some kind of fix! So now I have 2, QSCs, 2 Crowns & 4 Pyles driving my system
Apr 27, 2009 | Pyle PT-2000 Amplifier
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Amp protection mode
Try swapping the "bad" fuses for the "good" ones and see if that helps. That will tell you if the fuses are the problem. I doubt that is the problem. You never said what kind of problem you were having with the left speaker. If your friend dropped a drink into the amp then I would discontinue using it until it was checked out and don't be surprised if you have one channel that has some parts that need replacing, like some of the output transistors/MOSFET's. That might explain why your fuses appear to be melted. Maybe they are. In any case, get someone who knows what they are looking at to have a look see at your amp.
Jan 17, 2007 | Pyle PT-3200 Amplifier Car Audio Amplifier
Pyle PT-2000 Amplifier Logo
271 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
