Question about Sony Playstation 3 (PS3) Console
Repairing Playstation 3
The console was knocked off the end table and fell onto the floor. There is minimal cosmetic damage to the front right corner (bent plastic). The game still works, however the eject button does not, leaving the game stuck inside (a rental to boot). We sent it to Sony for repair & they returned it without touching it stating "Extensive Damage". When we called they said they do not have the ability to repair PS3 at this time, but may sometime in the future. Is this right?!! A $700 system that can't be repaired? It's only a few months old, any suggestions?
    Scholar:
  • 57 Answers
Cruark Something funny in Sony's response but I wont get into game console red tape. Several options, I commend you for attempting to tell Sony the legal reason of what happen. Most would say it was a store packaging error while shelving there floors and you were unaware of it {wink}. Here is some options, You may want to attempt to buy a broken one on eBay and use the shell on yours and the pieces of the eject button also. {make 1 good one out of 2} Some people like to buy the differant colored cases and you can do that also which would replace your case meaning you have to open it up but since Sony doesnt want to help anyways what will it matter. You can also open it up and see what minor repairs you can do with just a visual. Either way, hope these Ideas help.
Posted on Sep 19, 2007
How do I known if the front frame rails are bent
The checking of the frame rails for accident damage can be done easily. First place the vehicle over a flat clean cement floor. Select points on the frame rails such as front ends---suspension points---brackets attached to the rails on both sides and rear ends of rail. Make sure the points selected have a corresponding point on the other rail. Using a plumb bob drop the selected point to the floor and make a cross on the floor at that point. . Repeat the process for each selected point. The more points the easier to find where the rails are bent and by how much. Move the car out of the way and using a tape measure the distance diagonally between same points.-- EI-- from left hand front end to right hand rear end. Repeat the measuring from the opposite corners By measuring from one point on one side to the second point on the other side you will develop a continually crossing pattern of measurements. So in the end if you selected 4 points per side you will have 3 sets diagonal measurements on the floor or more . As you measure write the dimension on the floor. Now if there is a difference of more than 1/4 "(6mm)between any set of diagonals you will see if the rails are bent and if they are bent right or left or bowed in the middle. By measuring the heights of the corresponding points and recording them you will see if the rails are bent up or down. I understand it is a bit long winded but you will be in effect transposing the measurements of the points of the rails onto the floor so that the differences can be measured without the problems of items interfering with straight line distances.
Sep 20, 2013 | 1993 GMC Jimmy
My ps2 slim is not spinning the game inside it fell by accident and now it not working but it turns off and on but doesn't spin the disk
You most likely knocked something loose that is interfering with the lens. Or the lens is permanently damaged. If this is the case, you can purchase a replacement lens and by following online video guides, you can replace your broken lens with minimal fuss.
Oct 29, 2010 | Sony PlayStation 2 Slimline Console
Play station fell on the floor and the top is cracked. The screen turns blue when it comes on but will not read any discs nor open door.
well it sounds like the sensor for reading disc is broke it will not read anymore disc the disc tray is also stuck will not open without repairs and the screen is turning blue because the video output inside the console(this transfers the picture onto the screen is busted if u have a warranty use it contact playstation by going to playstation.com hope this helps you.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
External hard drive fell off table now ''drive not found''
these drives are a bit delicate and do tend to damage easily when dropped. You may just have knocked a cable loose, could have damaged the usb controller board or may have damaged the HDD.
If you're not concerned about warranty, you can slide the shell off of the body of the drive with a little prying around the back edge(around the metal end with all the plugs. It can be put back when you're done but you will likely leave some tool marks on it.
Once you have it open you will see the HDD mounted along the cases length, at one end it has two small cables attached. ensure they are snug, then follow each to it's other end and ensure they are snug, the check the small circuit board running perpendicular to the HDD to ensute the pinned end it securely attached to the larger ciruit board.
Test the drive, if no luck the next step involves buying a new drive enclosure. Go to you local computer store and ask for a 3.5" SATA Hard Drive enclosure. Then finish disassembling the Western Digital, removing the HDD and placing it in the new Enclosure, be careful not to touch the circuit board attached to the bottom of the hard drive.
Once you've installed the HDD in the new enclosure plug it into your computer and power it up. If this works your done, if not the HDD may be finished.
Still if this doesn't work you can send the HDD for recovery to a pro, try Armor-IT Data Recovery in Canada, they have good rates and are listed on FixYa's directory.
Hope this helps FixYa
Chris
May 10, 2009 | Western Digital 250GB MyBook External USB...
PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
Playstation was knocked off table and drive will not turn now!
ok since i cant see all of your question the im led to belive that you said it fel and dont work why? yes their is a million things mine did that i lanched it a a wall it turned on their that unpredictable open it up pull on every wire if you found a end to one the start lookin were you plug it back in
Jul 26, 2008 | Sony PlayStation 2 (PS2) Console
I dropped my Playstation 3
Send it in man but dont tell them what happened just say one day it started doing that.
Apr 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
282 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
