Question about HP Pavilion dv6000z Notebook
Power chord must must moved continually to show charge
Power lost to computer...port seems loose, but turning & bending power chord at port makes system charge..
Can problem be isolated to determine wire defect or port defect problem with power supply?
Is this a common problem? Does HP gurantee parts?
  • HP Master
  • 32,281 Answers
Yes, this is common, if the power cord at the connector is flexed continually then the metal fibres in the cord will break due to metal fatigue.
You can cut off the connector away from the break and fit a new connector on the cord, make sure the the wires are soldered correctly to provide the correct polarity at the connector.
The problem could be at the laptop where the connector plugs into the laptop's power socket. It could have a dry solder joint or the socket is faulty. This requires dismantling to repair.
The HP warranty would cover the normal warranty period and would not extended for worn parts.
Posted on Apr 16, 2009
I lost the power chord to the remote on my George sound system by Chestnut Hill
unfortunately it seems the George is no longer available. However, the power cord is a USB cord then you should be able to replace it by picking up a multiple USB cord kit (the one that has both the standard and mini sized cords).
May 23, 2014 | Apple Chestnut Hill Sound GEORGE Compact...
Speakers not Charging
Make sure the power cord is completely plugged into the back of the speakers. make sure the speakers power button/switch/knob is turned on. if both of these things are not the reason call the company you got them from and ask about a warranty.
Mar 02, 2014 | Brookstone Audio Players & Recorders
At first computer operated with battery. Battery stopped charging then computer would not power up at all. With or without battery. Tried different adapter still computer would not power on. What are...
Check the power port and try wiggling it. If you find it loose, tighten it. If same problem occurs, then you need to open up the computer to test the power supply and all the components including loose wire connections.
Thank you!
Dec 04, 2009 | Dell Inspiron 1318 Notebook
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
Computer stopped receiving power and won't turn on.
When you move the hard drive from one computer, it won't boot up unless the both computers are exactly the same model and configuration and with the same installed devices.
Generally you need to install Windows again to get a functioning computer when you transfer a hard disk into another computer.
Jul 29, 2009 | Gateway MX8711 Notebook
Envy charge port keeps breaking
Try this one open your verizon phone.remove the shield can.. the one that covers all the components. See the usb port?solder both side of the usb connector to the ground.. that will make the connector stable and prevents from port from breaking
Dec 22, 2008 | LG enV VX9900 Cellular Phone
Problem power chord
The problem that you Actually Have, Is that the Mains In DC Jack on the Motherboard. Has worked Loose.
You need this replacing A.S.A.P as it,s burning your power packs out, it,s also possibly arcing across the motherboard.
If you look on the internets largest Auction Site :) services are offered to repair these. Usually varying From £40-$80. Plus, Dependant on sending the complete laptop, or just Motherboard.
Alternatively A Computer repair centre. I,d estimated £100-$200 Maximum. But worth Doing to save your Motherboard And future power pack purchases.
Mike @ Compurepair.
Jun 26, 2008 | Acer Aspire 1642WLMi Notebook
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
HP Pavilion dv6000z Notebook Logo
187 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
