Question about Sony Cyber-shot DSC-N1 Digital Camera
Pink sony cybershot DCSW55
When I insert the battery, the little red light beside the battery begins to blink. Then I have to turn the camera on using the 'review' button and once I turn the camera off, the power button and the red battery light continue to blink on and off until eventually it drains the battery. Please help!!
  • Anonymous Apr 16, 2008
    when I insert the battery, the little red light beside the battery
    begins to blink.Once I turn the camera off, the power button and the red
    battery light continue to blink on and off . What does the red led by the battery indicate ?
    Also.....the flash does not work anymore. The camera was dipped in the pool
    for a nano second....camera did get wet. I took the camera front and back plastic cover off and used a blow dryer at a distance for 2-3 hours.....turning it at different angles so the warm air would pass thru it. I monitored the temp with a remote temp probe. kept the temp around 95 degrees/dryer 2 feet away.
    After putting it back together.....everything works....but the flash.
    The "red" light comes on....the picture snaps....but no flash. Checked the flash settings and the flash is in the "on" mode.
    Any input on what is wrong.....did the cap for the flash die? Did the bulb die? Let me know.....Bob Aldworth
  • Sony Master
  • 890 Answers
Please replace the battery pack and check the operation.
Posted on May 27, 2011
6ya staff
SOURCE:
My camera will turn on, then when screen is on for about 5 seconds, the screen turns off, and the red light beside the SIM card slot starts flashing.
Take out memory card form camera and turn it On, if camera stays On and shows normal view that means memory card is bad and causing problem.
Put new memory card in camera and take pictures.
Thanks.
Nov 04, 2010 | Sony Cybershot DSCW370 Digital Camera
My cybershot 12.1 megapixels touchscreen camera got a little wet from my hands and now it will not start. There is a red light when i insert the battery which blinks. Also the green light from power comes...
There may be still some moisture inside, remove the battery again, open any doors in the camera and put it in an airing cupboard or something similar and leave it for a couple of days.
Meanwhile, have a look at your user manual, check out what the red alarm light means, it may give a clue.
Then try again.....................Good luck.
May 03, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Broken battery cover on pink sony cybershot dsc-t70 replacement?
I know for a fact that this company, Teleplan Camera Repair, replaces battery covers. They would have your part for you.
Apr 09, 2010 | Sony DSC-T70 Digital Camera
My cybershot dsc s730 Camera wont start. all I did was but new rechargeble batteries in and tried to push the power button, only thing happening is little red light on bottom next to erase button. Please...
Take out memory card from camera and try to turn On camera. If camera turns On that means memory card is defective.
If camera still does not turn On then check new batteries and make sure both are good and last is camera main board is bad, this is not repairable part so new camera is good option.
Thanks.
Jan 30, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
My camer won't turn on
Does the lense extend when you power it on in "snapshot"mode?
Could be the switch is sticking. These cameras use concave cup button that mash on gold foil on the circuit board. Could be a bad switch. $$$$$ costly.
Interested in selling it?
Email me
[email protected]
Oct 26, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
97 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
