Question about Dell Power Supply 330 Watts nps-330cb (NPS330CB) Power Supply
Use nps-330ab for a normal power supply
I would like to use my nps-330ab as a power-supply for a car-radio.
what do i have to do, to get out 12V DC without connecting to a pc
  • wurstbauer Apr 15, 2009
    my power supply dell nps-330ab do not have these pins. it has a board comming out of one end with many golden contacts.
    how to do?
  • Dany Tery Jun 14, 2014
    try youtube
To turn on a pc power supply without the pc is simple. among all the wires there is only one green wire and there is only one grey wire: just bridge the two and the power supply will stay on. a yellow and black wire is 12volts (yellow is +, black is -). in case you short the outputs it will go off; just disconnect the mains supply for a few seconds and then put it back on.
Posted on Jun 22, 2010
    President:
  • 948 Answers
You need to ground pin 14 momentarily to turn the power supply on. Pin 10 provides +12v, pin 12 provides -12v. Diagram here.
Posted on Apr 15, 2009
  • Dick
    Dick Apr 15, 2009
    If it does not have those pins it is not a Dell power supply, it is only part of a Dell power supply. Without knowing exactly what part(s) of the power supply you have it is impossible to tell you what to do.
  • dimitri588 Oct 01, 2010
    DickCanFixIt, hi, I have a question, one day my dell inspiron 690 did not show any signs of life. I bought a NPS1000 AB-1A power supply, put it in, same thing, I did the pin 14 to ground, power supply turns on, but as soon as I connect the same connector with pin14 in the mother board with the ground shorted, it does not turn on the computer. is that normal, or is that a protection? there are 2 motherboard connectors, with the pin 14 grounded it turns on all the fans, but with thesame connector not connected, when connected to motherboard, all fans go off. pls help
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
Connecting speakers to a pc
The 12v dc power supply is for the speakers. There should be a spot for it on them. All modern PCs use power speakers, since the sound cards have no amplifier.
Jan 31, 2012 | Computers & Internet
My dash lights and my radio stop workin when i was installing a new radio, how can i fix this?
sounds like you have a problem with the power supply. Check the fuse. if ok, remove the new radio and check the power connection to the radio. if you cut into a wire harnis to find a hot 12v connection, you may have severed the dash 12v supply or knocked it loose . Take it slow and retrace your steps, but first check the fuse panel. You may have shorted out a wire without knowing it when attempting the install. lift the pos. lead on you battery the next time you play with 12v.
Sep 18, 2010 | 1994 Jeep Cherokee Country
Set up New PC Studio that is NPS then install USB drive
i have to install PC studio in my PC but when i tried it shown that my PC does not have NPS therefore it can not be installed. tell me how to install NPS.
May 30, 2010 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Set up NPS
while installing setup for samsnung mobile..a message appeared "NPS not exist "..wat do i do??
Aug 27, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Dell NPS-210AB power supply starts up then shuts off
hello bob, try putting a phanton loa on the other bars of the power supply, it seems tha the power supply is not starting, some switchin power supply require an apropiate load to start.
Jun 29, 2009 | Dell Power Supply 330 Watts nps-330cb...
Dell power supply NPS-210AB will not turn on
Try switching it with one that you are certain works just to make sure it didnt blow or that your computer is working alright. or, using a multimeter, try and check for any current flowing to any of the connectors...
Jun 21, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Radio Shack TRC-521 CB Radio
Dell - nps-200pb-73M not working
dont know the AC and the DC of my NPS-200PB-73M
Apr 25, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Computers & Internet Logo
1,189 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
