Question about Toshiba Satellite 1730CDS PC Notebook
Totaly dead after power input got shortcircuited
When I tried to replace the battery,accidently power connector pins shortcircuited while the charger was also connected.The computer is dead now.When inspecting the motherboard found some physical damages to miniature power mosfets.Replaced the same but the fault remains.Mother board is not drawing any power now.Pl help me to get my old laptop back to normal.Thank you.
Phone will not charge
Try cleaning the connectors (golden pins) that connects the handset to the base. It's likely that the connectors had got dirty, and electrical current wouldn't flow through them.
Or, the battery in the handset is dead, or faulty, and needs to be replaced. In most cases, you could replace the battery yourself. Batteries could be brought from your local electronics store, best buy stores, and, in some cases, RadioShack too.
Jan 31, 2014 | Uniden exi4560 2.4ghz extended range...
Battery problem
follow this test and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Nov 06, 2013 | LG Cell Phones
Iphone wont charge
follow this steps and fix it. God bless you
Jul 31, 2013 | Apple iPhone 3G
Samsung gt 55830 is not charging the battreies
follow the instruction and fix it. God bless you
Jul 27, 2013 | Samsung Cell Phones
Telefunken mr701 diagram
Jul 11, 2013 | Cell Phones
Turn off audible alarm when changing towers
God bless you
Jun 01, 2013 | HTC Cell Phones
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Not Pwering on despite changing batteries
Brand new batteries,totaly discharged,on charger 8 hrs,charger lite is off.Place batteries in camera ,error message "charge battery".Same with used batteries.Is the charger defective or is the camera defective .What to do ??????
Jul 09, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Toshiba Satellite 1730CDS PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
