Question about HP Scanjet 5470c Flatbed Scanner
No power No indicator lights or any sounds when plugged in and power button pushed. Can't seem to find anyone who fixes these. I always liked the quality of the output. Is it even worth trying to fix?
  • 5 more comments
  • Anonymous Nov 07, 2007
    I was using my HP scanjet 5470c and scanned several documents. The power just went out and I could not turn it on again. I'd like to know what the problem is and get it fixed. I love using this scanner.
    SAS
  • rdob Nov 08, 2007
    Same problem - Scanner was on, suddenly turned itself off - and now will not turn back on. Almost like something burned out (fuse?, transformer?)
  • Anonymous Nov 19, 2007
    same thing...
  • chsnamu Dec 18, 2007
    Same problem.
    I was going to try a new power adapter, as anyone tried that yet, or contacted HP?
  • Anonymous Jan 09, 2008
    I am a trained electrican and I just checked the power supply and mine is bad. I just got online to look for one if any knows were to get a replacement please notify me.
  • Old_Brown Feb 11, 2008
    My 5470C scanner stopped turning on after many turn-ons spuriously - when my Mac Mini - on the same powerstrip -had to be turned off/on when it crashed when and could not be reset. After a while the 5470C just would not turn on. I just tried it tonight and - yes- it does NOT turn on.
     The HP "Wall Wart"does NOT give any output voltage  when plugged in & not connected to the scanner.
  • Swordsmith Apr 05, 2008
    My HP 5470c worked fine until my computer crashed, and sat idle for two months while I built a new system. Now - it won't power on. No lights, no response to buttons; everything correctly cabled, s/w installed on new machine. Can't find a fuse on the unit that could be blown, and the power outlet is good.
    The HP troubleshooting is not helpful because the system does not recognize the scanner, so I can't change any settings.
    I suspect the power transformer, but it seems strange that it died while not in use. Frustrating, as it is a good scanner when it works...
Purchased an exact replacement for the power cable (less than $20 on Ebay) - scanner powers on!
Posted on Dec 27, 2007
  • 3 Answers
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
I would replace the power module (adaptor). Same issue happened to my 5400c in early November, too!
Happy Holidays!
Posted on Dec 01, 2007
Why is the Jandy RS6 Intellitouch Controller Extra Aux / Solar power plug always ON/Powered?
Your logic seems workable...
(I got nothing ... should work).
Trouble shooting says to check & clear "phantom"
programming... (Pg. 30: sounds like hokum 2 me).
My best advice..
Go to page 40 and contact their customer support.
Jandy AquaLink RS Installation Manual Warranty
1-707-776-8200
Carnac the Magnificent
Jun 22, 2014 | Jandy AquaLink RS All Button, Wired, RS6...
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
HP Pavillion ze5700 laptop wont start up
Hi, seems to be a wellknown problem of Pavillon NB's. Looks like that the northbridge chip on the mainboard ist unsoldered. Even if somebody tells you do fix it by dropping the mainboard into your baking oven for a few minutes, don't try it! There are specialists who have the technical equipment and the knowledge to fix that problem. But in most cases it would not held a long time.
Hans
Sep 09, 2017 | Computers & Internet
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
Astar LTV-32HGB blinking power indicator light
this sounds like typical power supply problems. these units have a stand-by power thats always active;even when unit is off. this allows the settings to be remembered by the u-con. (microprocessor) when you unplug the unit it will reset to factory default, thus erasing faulty power-supply data from improper voltages.(usually low readings) swollen capacitors on power-pcb will effect operation. recommend replacement of all electrolytic caps on power board. even smd's (surface-mounted-devices) can be leaky. they can be checked in circuit with an ESR meter. this is an analog sweep meter (needle gauge, not digital) that can detect faulty, leaky capacitors.
Mar 09, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Dell Latitude cpx
Well, when the power supply is plugged to the computer, there should be a light indicating that the battery is charging. One other thing, does it turn off completely (I should have asked this first) or is it just blocking? No messages on screen?
Oct 15, 2008 | Dell Latitude C610/C600 Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Lights are on, but wont start
The water pump can hum and still have a defective coil.
Jan 13, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
HP Scanjet 5470c Flatbed Scanner Logo
296 people viewed this question
Clive
Clive
