Question about Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass
Pegasus shower head/schematics
Looking for schematics for a pegasus sunflower showerhead installation - had a freezup and need to figure out the wokrings/replacement for the valve. Does anyone know where I cna get a copy? Tried googling to no avail....
  • 8,197 Answers
May I get the model # to help you more
Posted on Apr 05, 2010
Danze sunflower shower head only works with cold water
Hi, same problem i had faced and that time i didn't have much knowledge about pipe setting or plumbing stuffs.Please check the shower setting connections and make sure the hot water is in active mode or check the internal connection for pipes with faucets.i have given link for more information for showers .
http://www.a-general.com
Jun 10, 2014 | Danze & Sunflower Showerhead
How do i install showerhead
REmove old showerhead using two wrenches, one to hold the stem from the wall steady, then twist the head counterclockwise. Use the same wrenches to install the new one, twisting the head clockwise to tighten. But before you put it on, clean the threads on the stem with a rag and wrap teflon plumber's tape around the threads clockwise 4-5 turns. That keeps it from leaking and makes it easy to remove in the future.
May 26, 2014 | Hansgrohe Shower 27495 Raindance S 150 Air...
How do I get the showerhead apart. I have removed the 2 screws in the side of the head and the 6 nozzle bolts. There was 1 large screw/bolt removed in the head also. Now are the two parts pressed into...
At this point the two parts should come apart but are being held with lime build up and if you have lime-a-way soak it in that for awhile one to two hours should do it. If all you have is vinegar it my take all night.
Mar 09, 2011 | Pegasus Technologies Pegasus 6 In. Octagon...
How is this showerhead disassembled?
There is a fastener in the meddle of the part where water comes out. Loosen that and it simple from there on.
Feb 05, 2011 | Danze & 4" Round Sunflower Showerhead -...
The shower head has a leak around the ball area
Take the showerhead off above the ball. You may need to hold the pipe with one wrench and turn the showerhead with the other. Put teflon tape on the threads that are exposed on the pipe and then put the showerhead back on as tight as you can get it.
Sep 07, 2010 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Water does not come from the shower head
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Jul 24, 2009 | Delta & Single Handle Shower Faucet
Hours after I take a shower, the showerhead will start dribbing
No, the showerhead is probably OK. My guess is that the head is relatively level, and the design of the nozzle allows water to pool inside. When you take a hot shower and turn the shower off, it begins to cool. As the shower head cools, a slight vacuum is formed, pulling air up into the showerhead. As you reach equilibrium, water is allowed to discharge as a dribble. This continues until the water has all been displaced. The fix for this is to turn the showerhead to the side, allowing the water to drain more quickly, and allow the air in. Try it.
Best regards, --W/D--
Jul 21, 2009 | Moen Showhouse S112BN Waterhill 10...
Getting handheld showerhead plus rainhead - which valve? - a pressure reliefvalve or thermostatic valve
I installed a 2 thermostatic valves in our shower. Two of us can use both showerheads simultaneously without being frozen or scalded.
Kind Regards,
IT_handyman
Oct 25, 2008 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass Logo
1,345 people viewed this question
Top Union Home Experts
Donni Steen
Tom Chichester
Are you an Union Home Expert? Answer questions, earn points and help others
