Question about Garmin StreetPilot c530 GPS Receiver
Touch screen doesnt work all the time
When i turn on my garmin c530, the touch screen doesnt work. i need to turn off and on a couple of time to creect my problem
  • 385 Answers
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Regards
Richard.
Posted on May 19, 2009
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
How to reset garmin c530? thanks.
Pull the face off, press reset button under it,
then update it at Garmin's Web-updater website.
If it wiil not reset like this
Press the lower right corner of the screen, while turning on, keep pressing until the message
" do you want to remove all data " appears, click yes
Then re-register it at Garmin, then re-update it at Garmin
Should be good then
Regards
Richard.
May 18, 2009 | Garmin StreetPilot c530 GPS Receiver
Can't register my Garmin c530
Hi
You'll need to enter the serial number of your device, only after that you'll be able to select your c530 device from the list. However, if its not showing there then you can visit this link for update installation of your C530---
Garmin C530 Update
Garmin Product Registration Link
And, if you are unable to install the updates then you can visit this link for more details---
Garmin Support
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | Garmin StreetPilot c530 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
C530-Dead
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still exists then try to charge your gps from any external charger and check whether screen is working properly .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Dec 09, 2008 | Garmin StreetPilot c530 GPS Receiver
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. http://www.garmin.com/garmin/cms/site/us/support/supportcontactand the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
Garmin C530
There is a Master Reset procedure, but you would lose all of your favorites if you did it. To do a Master Reset, turn the unit off. Press and hold the on button and the bottom right of the screen at the same time. Release the on button when the unit comes on and asks if you want to do a Master Reset. Again, this will ERASE ALL OF YOUR FAVORITES.
Mar 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 won't turn on
Have a c530 I purchased 11/2006. In 12/2006 had 3 instances where I shut unit off and it would not turn on. Garmin had me do resets which did nothing. Had to leave unit to discharge for 3 days, then plugged in USB and it powered up and was fine (for a week or so). They gave me a new unit and at the same time a system software upgrade was available. The c530 was perfect through all of 2007. Then in Jan 2008, the same failures occurred 3 times. I discharged it 3 times and it now works, but for how long? My advice is to get anoher model. I have 5, c330's for over a year and they have had 100% reliability. l
Jan 25, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 street pilot
My Garmin c350 has a green screen after trying to update it for the first time and my computer will not read that it is connected.
It will not shut off after holding the power button down for 3 minutes
Dec 13, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot  c530 GPS Receiver Logo
70 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
