Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY kv-32FS100 5 blinks no sound/picture
Tv does not get any sound or picture.I get 5 red light blinks.After I unplug the tv from the wall and I plug It back in,tv will start by itself.Nobody I called doesn't want to help me about troubleshooting.
0 characters
1 Points
My sony trinitron is blinking red and won't turn on
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
No picture
Hi there, blinking lamp means that there is an error inside the set. When it blinks 5 times that means 1) C672 (0,047uF/600V) is bad 2) check the diode D503 (by replacing) 3) something is bad on a 135 Volt rail If you need more info you can contact me at LIVE session. Best regards, Arpi
Jun 16, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The red light on the front of the TV blinks all the time. No sound or picture. It is a Sony Model KV-21s65
The TV will cause the STANDBY light to blink or flash when the TV detects an issue.
The number of times the STANDBY light flashes corresponds to a specific issue.
If the TV is plugged into a power strip or a surge protector, please remove it from the power strip or the surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
Also try connecting the TV to different AC wall outlet and check if that helps.
If the issue persists, the TV needs to be Serviced.
The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired.
Please contact the local Authorized Service Center to get the TV serviced.
Nov 22, 2010 | Sony KV-32S65 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Sony KV-32FS120 No picture, No sounds, 5 red blinks after turned on
your problem is in power supply section in your tv. if it is ok check for h/output section. call skilled tech to fix it it is not a major problem.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
111 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
