Question about Sabrent SBT-RDIT PCI IDE Silicon Image RAID Host Controller Card RAID 0/1/0+1(For Both Low Profile P... (1801019)
HDD LED I have 3 plug in on the RDIT card -- however, I don't know which one the HDD LED should be plugged into? There is no explanation on the web as to which I should plug the HDD LED into. Does the HDD LED have to be plugged in? Or is this just for display of when the hard drives are busy as it indictes? One plug on the card is so far away from the plug that the HDD LED lead will not reach and the other two are at the just right ditance. Help
  • Anonymous Apr 26, 2009
    were do i plug in POWER LED ; POWER SW; H.D.D. LED
  • 44 Answers
You are correct, the HDD LED is simply for informational purposes and does not need to be connected. I took a look at the manual for you card (the pictures are pretty bad). It states:
"JP2 - HDD Busy LED Connector"
So are the pin headers labeled? They may have faint white printing near them (or on the back of the card). The one labeled JP2 should be the LED pins.
Posted on Dec 23, 2007
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
HDD led flashes non-stop after case swap (emachine et1331g-03w)
it will be next to ur power led or u will find hdd led wrritten on the motherboard
Jun 04, 2010 | E-Machines eMachines Desktop PC
I need to know where to plug in the 4-2 prong plugs for the power swich, reset swich, H.D.D led, and power led
We need to know what motherboard you have.
Each one is different, but if you look at the board with the back of the case to your left, the place to plug them in will be on the lower right hand side of the board. Many boards have the pin IDs printed on the board. Look there first.
I'm thinking you have a new motherboard. If you do, it came with instructions. If you got it from someone else, you can probably find instructions on the web--just google the motherboard manufacturer's name along with the number of the motherboard.
Note that when plugging in those plugs, the negative is always to the right. This will be the white wire on all plugs but the speaker and there it will be the black wire.
If this isn't really clear, just let me know.
May 04, 2009 | Computers & Internet
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Need schematics for front panel , power sw , pwr led , hdd led et
Try this link to Emachines page. After you put in the make and model and stuff you should be able to view the user manual for your machine. If this isn't what you need you are able to contact support from this page and maybe they can direct you to a more detailed explanation that may help more.
eMachines use specially-made boards for them so there is no manual as such as the boards aren't made to be distributed. Basically they would all use the same sort of connectors and blocks (and cases) to an extent that anybody can plug a connector into the right place and it will work.
The easy way to get round this is to find the power button first - try each two pin connector first, press the button and see if it comes on. If not, move along on the block until you find the right one. Then it's just a case of trial-and-error on the other ones to find reset, power LED and HDD led.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W4065
Mar 15, 2009 | E-Machines eMachines Desktop PC
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Sabrent SBT-RDIT PCI IDE Silicon Image RAID Host Controller Card RAID 0/1/0+1(For Both Low Profile P... (1801019) Logo
235 people viewed this question
Top Sabrent Computers & Internet Experts
Colin Stickland
Colin Stickland
Alun Cox
Larry Rider
Larry Rider
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
