Laptop does not boot up when you press the power on button. I have not used this computer for a number of years and I'm sure that the battery is dead. Do you need the battery to run on AC? The cmos cl
I have a NEC versa 2635cd laptop. I have not used this computer over the last two years, but recently had a need for it. When I used it last there were no problems at all but now when I plug in the ac power supply and push the power on button nothing happens. I'm sure the battery is dead but I do not believe that you need the battery to run on AC do you? The indicator LED on the laptop lights up when you plug in the AC adaptor but the computer does not boot up and no screen activity. I believe there is another battery in this computer a cmos clock battery, if this battery is dead will that prevent the computer from booting up? Any technical advise would be appreciated Thank You!!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Here is what i can say:
no you do not need a battery to run ac
you do not need a cmos battery to bot
Does the light stay on?
if so find a way to check if the screenis working.the connectors may be disconnected.
try useing an external monitor
Posted on Apr 15, 2009
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
Toshiba Laptop will not boot
Either the battery is dead or the power supply is damaged.
Mar 19, 2014 | Toshiba Satellite L875ds7332 Notebook...
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
My computer is not detecting my battery. Also it appears not to be charging
Hi, Shutdown the system , and disconnect the battery from the laptop.Also disconnect the Ac adapter. There is a button the battery , press and check if there are any light the glow on the battery. If there are no lights that glow the battery is dead.
Press and hold down the power button for 10 sec. after removing the battery and the Ac adapter Reinsert the battery and connect the Ac adapter 1.Power on the system and tap on f2key slowly five to six times on the Dell logo screen 2. You would enter the blue screen 3. Using your down arrow key, go to the option that says battery info or battery health . Check if there are any error messages on the same. If the battery is not detected you would have to replace the battery
** Note ** normal life expectancy of the battery is one year.
Thanks for using fixya Porton 2
Nov 11, 2009 | Dell XPS M1330 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Compaq presario 2500 notebook won't boot
This sounds like a weird solution, but it worked for me. I recently bought a used Presario 2500, it worked when the guy showed it to me, when I got home it didn't work two days later. I tried several tips from the web, finally I started pushing several buttons randomly. I pushed the Email (Envelope) button, and the computer powered on suddenly. Now, the Envelope button is the only button that will power the computer on. When the computer is on, that button will also bring up Outlook, but when the computer is off, that button turns it on. Let me know if this fixes it for you.
Dec 11, 2008 | HP Compaq Presario 2500LA Notebook
Will not boot
If this is a laptop quickly release the button after you press it.
Jul 08, 2008 | HP Pavilion dv6000z Notebook
Presario V5000
Battery must be busted...
Have you tried replacing it?
Also, try pressing and holding the power button.
Dec 15, 2007 | HP Compaq Presario V5000Z Notebook
Computers & Internet Logo
382 people viewed this question
David Payne
David Payne
