Question about HP Pavilion dv2000t Notebook
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
I have bought HP Pavilion dv2910tx, but I am not able to install Windows XP. Problem is "setup was not able to detect any hard disks attached to the machine. check whether a hard disk is being attached and it is turned on"
please help me in fixing this problem...and if possible then tell me the procedure to install Win XP in HP Pavilion dv2910tx.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
It needs xp bootable cd with sata drivers ,,otherwise sata drivers has to install with floppy.......
Posted on Oct 28, 2009
  • 25 Answers
Ara baba pleas go in bious abd change sata settings it will solve your problem
Posted on Apr 22, 2010
  • HP Master
  • 32,281 Answers
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Posted on Apr 16, 2009
4 Suggested Answers
mailtoravi
  • 186 Answers
SOURCE: XP on HP Pavilion dv2000
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
http://downloadmirror.intel.com/16023/a08/infinst_autol.exe
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Conexant High Definition(HD) audio :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
http://downloadmirror.intel.com/16944/a08/win2k_xp14363.exe
Download the Ricoh 5-in-one Card Reader Driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37712.exe
Download Intel PRO/Wireless Drivers from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34489.exe
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33574.exe
Realtek Ethernet Drivers :
http://drivers.softpedia.com/progDownload/Realtek-RTLRTLRTLRTL-Driver--WHQL-Download-33009.html
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
ftp://ftp.hp.com/pub/softlib/software10/COL24713/gs-63707-1/Marvell_Yukon_LAN_Driver_6.36.0.0.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the HP Quick Launch Buttons drives from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Download the HP Pavilion Webcam Driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Alps Touchpad driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33751.exe
Finger Print Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32869.exe
Hope these helps...
Posted on Oct 15, 2008
ginko
  • 19396 Answers
SOURCE: problem on loadind windows xp on hp pavilion dv2000 laptop
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Posted on Apr 15, 2009
you need a usb floppy drive for this task. I have done it but facing the problem with drivers
Posted on Apr 23, 2009
Hp a1340 new ram windows freezes
I would recommend a fresh install of Windows. Back everything up with the 1GB installed, turn off PC, install the second stick of RAM and then go straight to installing Windows.
Feb 27, 2014 | HP Pavilion a1340n PC Desktop
Is it possible to install Win7 update on replacement HD - a HP Pavilion dv4000 Notebook PC
It should be possible. You should search a free toll number for your country to ask Microsoft about this situation. Also you can take out your old hdd and use Ghost to mirror it on the new hdd :) - you just clone the old hdd
Jan 01, 2013 | HP Pavilion Computers & Internet
Windows 7 hp audio hp pavilion dv1000 drivers I upgraded to windoes 7 from xp and i have no sound went to alot of sites but nothing
Sir, i have HP Pavilion dv 1000 (XP operating system). Recently, i upgrade it by Window 7 but Now audio driver is not working properly now. pl suggest to solve it.----- pratik
Jan 10, 2010 | HP Pavilion dv1000 Notebook
How to downgrade vista to winxp pro at Hp pavilion DV4-1204TU ?
Well, this may make you think twice:
I bought a presario from circuit city last year, and I paid $200 to downgrade to XP. Everything was fine until it crashed last week. IT went completely bizzerk. HP won't provide support, cause I changed it. Circuit City is out of business, not much help there.
Basically, I am completely #$%%@@.
I am now paying to get Vista put back in. :-(
Jun 09, 2009 | HP Computers & Internet
Drivers Problem with HP & Windows Xp
use the supplied drivers cd for re-installation of drivers.  if u dont have drivers disk use the link below for download drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3750706&#
Nov 18, 2008 | HP Compaq Motherboard
How to install Widnows xp on HP Pavilion dv2000
Please help me, I bought a HP Pavillion dv2000 Laptop which came with a built-in Windows Vista. Thats cool, but the problem arises when I try to install windows XP. After inserting the Windows XP SP2 CD and after primary driver loading it is unable to detect my harddisk
May 07, 2008 | Computers & Internet
How to install windows xp over utubut?
habibi,
to install XP:
1). you must have Windows XP setup disk.
2). If your HDD is SATA interface then error message will be raise...No Hard Disk Found. To fix this problem goto BIOS setup and Make SATA disabled. then try to install.
For more help just Ask me.
Thanks
Iqbal
Apr 02, 2008 | HP Pavilion dv6000z Notebook
Unable to format my laptop
The easyest way to format is with windows xp disk acting as a boot get into dos and format or install dos.
Feb 11, 2008 | HP Pavilion dv4000 Notebook
HP Quick Play not working
in the software backups there will be the installations for "HP Quick Play" Re install it from There ... if You dont have the back up ... Download it from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-45931-1&lc=en&cc=us&dlc=en&product=1817074&os=2093&lang=en
Oct 01, 2007 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t Notebook Logo
676 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
