Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Unable to charge
By liamfitz on Sep 14, 2007
phone unable to chaRGE ABNY SOLUTIONS
Same Problem
Apr 04, 2009
-   I have two razr phones both say the same thing "unable to charge" I bought a new battery and it still says the same thing. I use both home and car charger and neither one works.
-   Guest
Mar 21, 2009
-   when charger is connected in off mode the screen displays "unable to charge" in motorola v3i.-   Guest
Feb 19, 2009
-   phone wont charge it says unable to charge
-   Guest
Sep 16, 2008
-   unable to charge--reding on screen. 2 weeks old-   gemmabooth
Best Solution
posted on Apr 14, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try this solution it worked for me....charge with a standard usb cable (you'd need to install USB driver on your PC)
http://www.noheat.com/2007/01/31/charge-motorola-razr-with-standard-usb-cable-from-pc/#comment-159464
//Brian
Solution #2
posted on Sep 14, 2007
Helpful)
mixmaster
Rank: Guru
Rating: 90%, 1615 votes
There could be corrosion on the charger, or the connection on the phone?
If so, remove the battery and clean them both with a toothbrush and Isopropyl Alcohol.
The phone may have gotten wet?
Check behind the battery, there is a water indicator. Its normally white, if its gotten wet, it will be red.
Best of Luck.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Dec 22, 2007
Somewhat Helpful)
kpenguin
Rank: Wiz
Rating: 84%, 74 votes
Be sure to check the contacts.
I will also check to see if the car charger works vs. the regular plug.
Was this helpful?
Yes
No
Solution #4
posted on Oct 03, 2008
Very Helpful)
Snowneo
Rank: Apprentice
Rating: 100%, 1 votes
I had this problem also, try turning off your phone and turning it back on.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Feb 20, 2009
Not Rated)
eng Abdul
Rank: Apprentice
Rating: 0%, 0 votes
IS THE GARGING POINT
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
when you turn it on it says' insert sim card', but it is in already
Answer
hii all i have a motorola v3 which is very good phone but became old its camera is vga with noo... (More)
Answer
my phone lock on the # button when i open ot and no other buttons work on it
Answer
when i turn on my motorola v3 it appears something like data error ph err:35:02 something bootloader... (More)
Answer
i blocked someone and now i want to unblock them
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola RAZR V3 Cellular...:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
