Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
Cant access my d-link wireless access point
I can access my login screen but dont have a password
    Brigadier General:
  • 6,966 Answers
Hi, seems you posted twice, here's the link to the your other post with response.
Posted on Sep 15, 2007
Ll i need to put password to my accese point (dlink) please tell me how ?
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes but D-Link provides an easy to walk through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button.
Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply." Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
Feb 19, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
My router is nortel BAP120 and after using reset option it is not able to finding by search and 11b/g sign also disapper on router what should i do?
AFTER reset access-point disables wireless access so you need to connect CAT5 cable to pc and Access-point then type in your browser
User Name nnadmin
Password PlsChgMe!
login with above details and reconfigure wireless and other properties of your access point.
Mar 29, 2013 | Nortel BAP120 802.11a/b/g Wireless Access...
I cant log in my wireless device dlink on i want set the password and i cant
the first time you access it will ask you for username and password. Type the default username and password. If you don't know try one of these:
Username: admin
Password: password
Username: admin
Password: No password (just hit enter after you type the username)
Username: admin
Password: admin
Dec 07, 2012 | D-Link Dlink Airplus Xtreme Dwl-2100ap...
Hi i have a d-link dwl-g700ap and i cant acces the wifi from my garmin-asus a50 nuvifone , i know its not the phone because i can connect on everyother network . please help
Go to your management software inside the access point. Default IP address is If you changed it, go to that address with a browser. Default login with "Admin" without a password. If you set up a different administrator id and password then login with those credentials.
Go to the "Advanced" tab. The setting on the MAC address settings are important here. Hopefully you know how to get the MAC address of the phone. I don' have the same phone so I can't tell you how to get it. Ensure that you have entered in the phone's MAC address and any other devices that you connect wirelessly to. If you have registered the MAC address under the second radio button or you have the first radio button clicked, you have a WEP or other password issue. Many public access point don't filter any MAC address and don't require passwords. When setting up at home, you do have to at least these up.
Hope this helps.
Aug 06, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
I want to know how i can make my Linksys Router WRT160N work as access point
By default Linksys router behaves as Access point. On some router you have to enable the wireless function.
So the following to configure the router Wireless Access Point
Click the below link
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts. You can connect as many devices as you wish since it is a access point
Vote me If it helps
Apr 26, 2011 | Linksys WRT160N Wireless Router
Router login problem
There is some information on the following link:
Also you can reset the access point, by putting a paper clip into the reset hole for a few seconds. I think the default username and password is "admin"
Jan 03, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Resetting fulbond wireless AP
problem solved when im using access point manager to accessed my wap.
the default password is "default". for unknown reason the wap seems cant be access thru http, even i enter the right password. the http page tell me that the password is wrong. But when i used access point manager from i can log in to the wap and configure it using the same password that i used on the http page.till now still dont know what's wrong with the wap.
since it's working fine im not trying to find out anymore.
the default password is working too on telnet and others but it still dont work on http page and i dont
see any configuration that restricted access to the wap thru http access.
Nov 21, 2008 | Arris WA840G 802.11g/b (49832000100)...
(Work this one out) My access point works but I have never been able to set security settings on interrogate it.
try typing in your internet browser..the login and password are usually admin  and admin can then configure further settings without using any cd etc.hope it helps!
Oct 22, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Cant access my D-link access point
Hi, If settings of username and password are still at default, they are "admin" and 'leave it blank' respectively. If these have been changed in the past, then you have no alternative but to do a hard reset (press reset button at the back or underneath) to restore everything to factory default. Of course this would remove all changes and settings that you have done including configuration. Hope this be of some help. Post back how things are or should you need further information. Good luck and kind regards.
Sep 14, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
122 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
