Question about Necchi 3101 Mechanical Sewing Machine
Necchi Esperia tension problem
I have an opportunity to buy a Necchi Esperia (1958-1961). The tension may need some work. Are there any notable problems that I should be aware of with this machine? I'm just a basic threadbanger. No embroidery, no quilting. -Joanne
SOURCE: NECCHI 525FA
I have a brand new 525FA. I can try to take a pic of it tomorrow for you. I may have to call my mom to see what part you need a picture of cause I'm not familiar with sewing machine parts at all. But I'll check with her. Or maybe you can take a pick of what you need to see. Then I can look at it, and take a pic of the same thing on mine.
Posted on Jan 14, 2008
  • 22 Answers
SOURCE: I need a walking foot for a Necchi Model 4795 for Quilting.
http://www.sew4less.com/product/2034/Low_ShankEven_Feed_and_Walking_Foot_and_Quilting_Foot_10449
Posted on Jan 12, 2009
  • 69 Answers
SOURCE: Tension trobleshooting
The proper tension for the 537 is between 4-6. You need to make sure that your presser foot is in the up position before threading.
Posted on Mar 01, 2009
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
bargainbox
  • 1388 Answers
SOURCE: I need to replace my Upper Tension Dial on my
Before you feel the need to replace this unit, try this to see if it helps... Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 08, 2009
Can a bobbin case be purchased for a Necchi sewing machine Nova esperia Not sure what the model is. There is a number 29-0016972 on the frame.
If you have the old bobbin case, take it and the make/model to the local sewing repair shop. They will either have one in stock or can order one for you.
Apr 14, 2017 | Necchi Sewing Machines
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
Where can i find info on a necchi esperia 18-0045885
are you wanting a instruction manual?
Mar 21, 2012 | Sewing Machines
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Necchi 511..how do you adjust thread tension on top thread
Before the thread goes though the uptake lever, it goes though the tension (a round "knob" with numbers).
When threading the machine, lift the presser foot. This opens the tension control so the thread can enter and then when the foot is down and you begin to sew, the tension setting will determine how much thread should feed to the needle.
The setting is usually around 4. However, if this is an older machine that has been used a lot and serviced a little, the tension may not work as it should.
Try different settings and if you cannot get a proper stitch, you will need to determine if the machine should be serviced or if you should purchase a new one - service and parts can be 1/2 the price of a decent, new machine.
Feb 28, 2010 | Necchi Sewing Machines
Zig zag stitch
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
Jan 14, 2009 | Necchi 6011
3102fb tension
I have never been able to find the knob you are writing about soooo_
You will need to buy a new tension assembly. They come in different sizes so the best thing will be to take it to a technician. should be able to have it replaced for under $25
sewman7
Jul 09, 2008 | Necchi 3101 Mechanical Sewing Machine
NECCHI Sew line 20 manual needed
Hi did u have any luck have the same machine?
Jun 30, 2008 | Necchi Sewing Machines
Necchi 3101 Mechanical Sewing Machine Logo
171 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
