Question about Hitachi 43UWX10B 43" Rear Projection Television
Everytime I turn on the tv is won't turn on. so I just keep on clicking. After clicking so many times it finally turn on. afraid to turn it off and might won't turn on again. what seem the problems?
  • 371 Answers
Try changing the batteries in your remote, for starters. It seems to be a simple matter of a defective switch.
minor service routine if it's happening when you turn on the set at the console.
Posted on Apr 16, 2009
I have an LG plasma tv model # 42pg20-ua. Everytime I try to turn it on the tv keeps clicking turning from blue to red. Tv never actually turns on. I keep trying to turn it on, but it just clicks and...
that is usually a t-con board or video card. ebayers usually have those parts reasonable.
that's how I fixed one of mine.
it could be the power board which is the costlier part.
Aug 01, 2017 | Televison & Video
2004 sebring won't start at all
sounds like you might have lost the altanator. Check the battary to see if it is very low, if so it was running of the battery and not the altanator. try charging the battery and see if it will run. If it does, checkthe voltage on the battery. it should be above 13 volts when runnig.If not it is the altanator.
Sep 15, 2012 | 2004 Chrysler Sebring
My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Feb 17, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tv clicks on and off for 1 min.. till it turns on
shut off your copier and let it rest for 10 mins.. and turn back on,
if it is still no good, call for repair!
Oct 22, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
HDTV problem-keeps turning off on initial power up
The fact that the set works after a while suggests that there are bad connections that the heat "fixes". If you can solder, open up the set and resolder any connections that appear grainy or have rings. That should resolve it unless there is a component that is starting to fail. Update this if the soldering does not fix it.
Dan
Mar 17, 2008 | Televison & Video
53 in HDTV with DVD player flat screen
What is your model number of your TV?
Jan 12, 2008 | Televison & Video
Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Dec 28, 2007 | Televison & Video
Hitachi 43UWX10B 43" Rear Projection Television Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
