Question about Onkyo TX-SR501 Receiver
Power loss While watching movies and listening to music the reciever will shut down for no apparant reason. The unit is not hot nor is it enclossed whithin a cabinet. I purchased a small axial fan and placed this fan on top of the unit to move air around it thinking it was gatting to hot. This did not solve the problem. The reciever shuts down and powers off after ten to fiftenn minutes of use.
  • Skeletor666 Feb 21, 2008
    I am having the same w problem the receiver shuts down for no apparent reason when watching movies, playing games, but not when listening to the tuner
  • 752 Answers
Its possible that one of the speakers wires are shorting out or touching the case of the unit (leads to protective shutdown).
Posted on Sep 15, 2007
SOURCE:
Why Intermitant Power Loss
Its probably a Power Supply failure replacing it will mostly fix your problem
Jun 20, 2014 | LG 42LD550 42 in. TV
My PC wont play album I requested.
You only need compatible dvd player software to listen to movie dvd disks. For playing standard audio cd disks, nothing is needed since this support comes built in-to the OS, (Windows XP or higher)
Apr 24, 2014 | Computers & Internet
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
AVR SR6004 switches off while BD player is playing. What do I do?
There are two circumstances that I know of that a properly installed unit such as your Marantz would shut down. So here is the Theory and Data I know of.
A Your receiver has a great deal of amplification power. If it is in a closed cabinet without excellent ventilation, it will shut down if used at high volumes because because over heating. Because of it's very high power, when played loudly, it generates excessive heat.
When watching certain movies the BD player may be over-driving the limits of the amplifier section of your receiver. Page 78 of your owner's manual addresses this. Here is a link to download the manual from Marantz.
http://us.marantz.com/us/Support/Pages/Manuals.aspx
B There is one other very important thing I should mention to you. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What tends to happen is that the listener and often the engineer running the sound mixing board at a concert(after a certain period of time) believes the sound is not loud enough when it really IS loud enough. (this tricks the audience as well) and engineer turns it up. After turning it up, his mind (and the audiences') turns it down mentally and they again think and agree that it not loud enough and then again, the volume level is turned up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours at 110 decibels. permenant hearing loss is exactly just that. Permenant! It just doesn't come back. If you use this information, you will enjoy hearing music for the rest of your life.
I hope this helps,
Best Regards,
Mark
Jan 22, 2011 | Marantz Audio Players & Recorders
My kenwood vr615 reciever had the volume turned up, unit shut down and now when it gets to a certain volume that is much lower than normal it will turn off and the stand-by light will flash, I have to turn...
hello ,i strongly suspect the units protect circuit is sensing a speaker problem.Listen to each speaker to see if all the drivers(woofer,midrange,tweeter) are working and if so are any of them sounding distorted.When an amp is damaged it wont play at all,sounds like a bad speaker to me.
Jan 09, 2011 | Kenwood VR615 Receiver
Battery Life Shortened
i have the exzact same problem with my laptop but its coz when u watch a movie, play games, listen to music or if ur using up a fair bit of memory it takes up battery life to store it all
Jul 24, 2009 | LG Dare VX9700 Cell Phone
AV reciever sound goes off
If it is working fine and then shuts off and gets hot in just a matter of seconds then you are in the process of frying your amp. Disconnect all speakers and recheck your speaker load. Try only one speaker on one channel and then one on the other channel at first. Or better still, while you have all the speakers removed, try listening on headphones and see what happens. It sounds like you have seriously overloaded your output transistors with the wrong speaker configuration. Good luck.
Jan 02, 2009 | Audio Players & Recorders
Fast forwarding movies and listening to movies without headphones
https://www.manualslib.com/manual/2384/Advent-Video-Mobile-Adv38.html#manual There is no speaker in this unit, so it's headphones only. The unit is not wired to an always hot fuse. Find a fuse that is always hot even when cranking the engine and the player won't start the movie over.
Apr 16, 2017 | Recoton Advent Advent DVD-8200 DVD Player
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Onkyo TX-SR501 Receiver Logo
196 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
