My problem about our destroyit 4005,red light always turned on which means lack of oil and the oil was not functioning automatically. Is there any sensor or switch so the pump will automatically work whenever it detects lack of oil?. Thanks
  • DanfordDan Cross
    DanfordDan Cross May 11, 2010
    What is this thing ? give more info, What kind of shredder is this
5 Suggested Answers
  • 4 Answers
SOURCE: light sensor
The light sensor is in the dash board top about 2/3rds of the way over toward the passenger side. You will see 3 or 4 small slits, and that is where it picks up the light, or absense of light. Is the twilight control switch, located under the main light switch, in the position to turn the lights on automatically? It is a slide type switch, and must be slid over to the right for the automatic control to work.
Posted on Oct 29, 2008
  • 70 Answers
SOURCE: Yamaha 50 hp motor oil red and green oil sensor lights are on
we have a red warning on Yamaha 50 hp 4 stroke outboard engine and it runs rough during forward,its ok if there is no load.
we have changed spark plug, engine oil also cleaned carburator .
looking for solutions
Posted on Jan 10, 2010
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Posted on Nov 23, 2010
Bothcoasts
  • 10 Answers
SOURCE: I need the location of the oil sensor switch for a 95 c280. Leaking oil whenever you turn off the car.
Go to Www.Benzworld.org/forums.
Put your question in there several people are talking about it. Hope that helps
Posted on Mar 20, 2016
Pacifica oil light
If the oil light is red it means engine oil pressure is below 10psi which can damage the engine. It does not always mean the engine oil level is low.
Jan 26, 2014 | Cars & Trucks
Oil will not pump and red oil light is on
You have to reset the oil indicator. Turn the machine on and then hold down the 'R' button for a few seconds. The oil lights will flash and then turn off and the machine will start drawing in the new oil.
Dec 10, 2013 | Destroyit 4005CC Shredder
Destroyit 5009 Shredder No power to the oil pump.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
Aug 27, 2013 | Destroyit 5009 Shredder
2007 magnum se 2.7 v6 wont turn over
Sounds like the engine is toast.
The warning light means the oil pressure has dropped below 10psi which can mean the engine is low on oil, or that something has happened to the oil pump or other components.
The crank bearings may be seized from lack of oil.
See if you can turn the crank by turning the alternator pulley.
Jan 26, 2013 | 2006 Dodge Magnum
JUST RECEIVED A NEW SHREDDER BUT THE MANUAL IS PRINTED IN GERMAN. CAN I GET AN ENGLISH COPY?
It's always wise to include model numbers when asking for assistance but you might find help on their website:
Destroyit
Mar 24, 2011 | Destroyit Office Equipment & Supplies
My 2001 9.5 saab red oil light and warning light is on but i have oil in the car
If you have oil in your engine this usually means you are lacking oil pressure. Saabs were prone to producing sludge at the mesh filter which blocks the oil getting to the sump and circulating properly.
Jan 04, 2011 | 2001 Saab 9-3
Engine light came on
You should never drive with a red engine light there is always the risk of further damage to engine,this could mean no or low oil pressure driving like that will damage the engine. Check oil level first check coolant level and get back to me.
Apr 05, 2010 | 2003 Honda CR-V
Maintenance light has turned red what does this mean
The maintenance light automatically starts flashing when you reach a certain mileage - it's to remind you that you need to do a regular maintenance: oil, filters pads, etc..
Mar 04, 2010 | 1992 Honda Accord
Red blinking light on wireless guitar for rockband on the ps2
Red light means ur game pad's analog function is on. If it is off then the function will b digital. Remember each game adjusts analog/digital function itself automatically. Plz feel free 2 ask ny problems related PS2.
Thank you,
KABID.
kms_pb@yahoo.com
Jun 09, 2009 | Sony PlayStation 2 (PS2) Console
I have the 2602 model and the indicator for the door being open stays lit even when the door is closed is there a way to fix this
Yes. There are two electromagnetic sensors (front and back). If defective, the main board will show a yellow or red light. These sensors function with the cabinet which is magnetized in the center (front and back).
Dec 29, 2008 | Destroyit 2602 Shredder
148 people viewed this question
k24674
