I keep getting a blank screen that says no operating system can be found
    President:
  • 1,865 Answers
1.Check your Bios settings to make sure it sees your hard drive
2. Check Bios setting under "boot" option, make sure hard drive is listed as boot device
3. Hard drive may have crashed
Posted on Apr 15, 2009
How do I get my laptop to come on it keep saying operating system not found
you have to reinstall your main operating system it is the disc that comes with your laptop when you bought it. if you dont have it you will need to get one such as windows 2000 or wich ever u have
Feb 08, 2013 | Computers & Internet
In wespro netbook the boot screen did not appear, it shows blank and blank, can you help me ?
Test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd have secure dust free connections and are not faulty even the electrical extensions
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
or you might try
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Jun 20, 2012 | Computers & Internet
Hp dv9208nr with vist sp2, system keeps rebooting, screen stays blank, cant even get to bios
hi,
When the files in your system are corrupted, your HP laptop would reboot automatically. When the files which are required to run the Operating System like fonts under Windows FONTS directory are been smashed then your system's Operating System will force your HP Laptops to restart continuously. Thus in such a situation you would have to change the name FONTS in the Windows directory.
Get more help to fix HP Laptop Keeps Rebooting error . Hope this helps you.
Apr 24, 2011 | HP Pavilion dv9000z Notebook
I have a dell monitor that the power light is on but yet the screen is blank? Changed both vga cable & power with no effect?
Pls check that the your system is working or hang on the blank screen .For system check pls press the Num lock button on your keyboard its on/off or not.If your keyboard Num lock button is on/off then Problem with your Monitor might be might be EHT is faulty its better call vendor for repair.If system hanged on blank screen then problem with your RAM OR Hard disk or Operating system.
For Hard disk pls remove the power cable from Hard disk and on the system if not resolve then
Go for RAM,remove the RAM chip and re-installed another goods RAM ano on the system, If still blank screen then Problem with Operating System .Get it re-installed Operating system
Nov 16, 2009 | Dell E173FP 17" LCD Monitor
Cinema Screen goes Blank intermittently
my tv, s name is SHARP 14inches cinema screen keeps blanking.
since threedays has any solution .
Aug 19, 2009 | Computers & Internet
How do I stop getting blank emails?
What operating system you use and where are you getting the blank emails from?
Look at the address as who sent it to you.
You may be sending it to yourself by mistake.
Are you using Yahoo, google or what e-mail system?
Apr 09, 2009 | Microsoft Computers & Internet
Operating System Not Found
On my Windows 7 laptop, I have got "Operating System not found" with black screen, to fix problem,Windows Boot Genius helped me finally!
Mar 17, 2009 | HP Computers & Internet
Pc will not boot up
First try switching on the system , and then keep pressing F8 and you will get a screen and select Safe Mode . Once logged in Lshut down and reboot
Dec 15, 2008 | Dell Microsoft Windows XP Home Edition
Operating system not found
This message means that the hard disk was not detected, this is due to either the BIOS setting was changed or the hard disk has failed.
Try booting up with a DOS disk and run FDISK, and see if it detects the hard drive, if possible run a diag test program.
Nov 22, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
