Question about Samsung Refrigerators
I have a samsung referigator.
Every 2 or 3 days I find pools of condensate on the floor. Whats wrong?
Thank You
    President:
  • 1,902 Answers
Remove all the thing out of your freezer, remove the inside back panel, and check your drain line to make sure that it is free from blockage and ice. Pour hot water down it to make sure that it is open. At the same time look at your coils and make sure that there is only a thin layer of Frost (not ice) on the coils.
Posted on Apr 15, 2009
Samsung model#rs253basb side by side/ water pooling under vegi drawer & leaking out onto floor. water dispenser works when it wants too-not very often these days.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Frigidaire FRT15G4B Top Freezer...
I have an amana abb2522feb bottom freezer refrigerator and need to access the drain pipe. How do I access this? The problem seems to be the drain line is clogged because we get a pool of water about...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Amana ARB9059CS Bottom Freezer...
02 taurus condensation pools in right floor, just need to know how to fix. Its not the rain.
Look under the car, under the right floor board toward the front for a small rubber tube, this is the a/c condensate drain tube, it coould be on the right side firewall under hood close to the bottom. Dirt wasps love to build nests inside these tubes, they become plugged and the condensate runs inside on your floor board on the right side, to clear it, grab ahold of it and squeeze it along the length and gently twist it back and forth, then operate the a/c and see that water is coming out of it. Hope this helps, let me know.
Aug 04, 2010 | 2002 Ford Taurus
Condensate accumulates on the passenger side floor board when running the AC. The AC runs cold, and when we park the TC, there is no condensate pool on the ground like you would expect to see from other...
The drain for the evaporator is stopped up,use compressed air,like a air tank and a blow gun.The drain is directly below where the ac lines go into the firewall.If this was at all helpful,please rate,thank you.
Jul 18, 2010 | 2001 Chrysler Town & Country
Pool heater want heat
Thank you for posting your question here on Fixya.com.
SF refers to the temperature sensor so short of disconnected or damaged wiring; you will need to replace the temp sensor. Your part number should be IDXLTER1930. We stock the original Hayward part and sell them for $48.94. If you want to order one use the contact feature found along the bottom of our page at www.arrowpools.net.
From your owner's manual found here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 20, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
How do you unclog the condensation drain on a GE gss25wgma model refrigerator? have water pooling and freezing on the freezer floor, spilling out onto the floor within days after removing it. Thanks!
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Jun 22, 2009 | GE GSS25JFM Side by Side Refrigerator
Water leaking from my refrigerator
seems to be a condensation proble, is it possible to lower down fridge temperature a bit? This may solve the problem.
Mar 19, 2008 | Refrigerators
Refrigerators Logo
153 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
