On boot up the bios is stating the CPU was changed. But it was not.
My asus p3b-f computer keeps stating that the CPU has been modified since it last booted up. But the CPU has not been changed. Could it be that the onboard battery is going bad?
  • 64 Answers
Yes, the battery will need to be replaced. Please rate me if this helps.
Posted on Apr 15, 2009
  • 3,267 Answers
Usually that is the first signal that the battery is drained and needs to be changed. Yes you are right, go ahead and change the onboard battery and set the time & date after that.........sodeep
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Asus g73jw black screen on boot up
That sounds like the GPU is cooked. The CPU is heating up trying to drive the GPU that is not responding.
Feb 13, 2014 | ASUS G73JW-XA1 17.3-Inch Gaming Laptop -...
My mother board asus p5v800-mx was having a bios corrupted.. it only display starting bios recovery..
Try these options if you mainboard is not booting!!
1. Clear CMOS. (Remove the CMOS Battery)
2. Remove your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Remove the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Keep the necessary components(CPU, one memory) onboard for a test.
Finally, recommend you to replace a BIOS battery to have a test.
Hope it helps.
Oct 11, 2010 | ASUS Computers & Internet
Need manual for a d33007 m/b
Here is what I found on Web? Good Luck :0)
http://www.user-guides.co.uk/download/diagram/diagramd33007/diagram-d33007-motherboard.html
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English Additional information on your ASUS Motherboards MainBoards. This manual has not been listed as either a service or user manual for your 1394 but may be of interest. 2 ASUS P3B 1394 4 ASUS P3B 1394 5 SOFTWARE SETUP 63 6 ASUS P3B 1394 6 SOFTWARE REFERENCE 7 APPENDIX 93 94 Part De ..... diagram d33007 motherboard ... lots more information here
Download And CD Available
Nov 11, 2009 | Computers & Internet
Asus P3B-F Motherboard
Download a manual from the ASUSTEK website, I have read many forums related to issue's with ram and from what I have learned with the ASUS boards is that dependind on the bios and the model, each slot, for some unknown reason can only recoqnize a maximum of 128MB per DIMM slot? My board has 4. For example, no matter what I install for Ram the motherboard will only read 512, some of the forums on ASUSTEK reccomend reflashing the bios with an updated one, but now, with the age of these computers i find it difficult to find a Bios upgrade. It is ridiculas, the Bios should come from the manufacturer ready to handle the maximum Ram of 1GB, which is my case with the ASUS P3B-F Pentium 3 with a 850MHZ processor.?????????
Jun 08, 2009 | ASUS Intel 440BX Chipset P3B-F Motherboard
Will not boot into XP
If you have a SATA HDD, lok in the BIOS for something along the lines of "configure SATA as:" When you changed BIOS settings, this could have changed. Change it to something different and try again. Otherwise there is a chance that you fried your CPU, sorry m8
Apr 29, 2009 | ASUS P4S800D-X Motherboard
Only cursor displayed in monitor
This is because you have not selected boot devoce priority to HDD first or ur hDD is not have aCTIVE PARTITION
Dec 19, 2008 | ASUS P3B-F Motherboard for Slot 1 CPU
P4s533 mainboard
Reset BIOS back to default
1) remove M/board battery for 5 to 10 minutes
or
while booting press the DEL or F2 or ctrl+esc
or check lower part of screen during boot will tell you hoe to fet into BIOS
Once BIOS reset to default boot computer if OK.
you can change BIOS to suite CPU etc
Oct 29, 2008 | ASUS P4S533-MX Motherboard
Problem with my bios
the first thing i would do is check// change the battery to see if it is any good because it looks like the battery may be bad causing the system to forget the time and things like that,,,, then the next time it boots into bios look at the time and date and location ect..ect section and make any changes to it that it may need , that is why they want you to make changes to the first 4 fields when it boots into bios is to select fail safe options if you have that option and see if it will boot . if not go to default settings ok please keep me posted on this i can help you aout a lot more if needed ok best regards mike
Aug 25, 2008 | ASUS P4S533 Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
