I have a three year old LG front load washer that has started to leak. I have replaced the hoses but the problem persists. Any suggestions before I call the repair man.
    President:
  • 1,902 Answers
Where is it leaking from? The front or the back? If it is from the front replace the door gasket. If it is leaking from the back you will need to remove the back panel and get into the drain line and make sure that the drain line from the pump to to outside drain line is ok and not broke or loose
Posted on Apr 15, 2009
My LG WM2650HWA front load washing machine is 13 months old. A few weeks ago I noticed water at the end of the cycle in the front of the machine. Upon further inspection I noticed soapy, water at the
It's very common for the sump hose to have a hole in it causing it to leak. The quickest way check is to tip the washer back and examine the sump hose by stretching it, as you stretch the hose you should find your leak. You'll also want to check the door gasket for cuts and the drain pump assembly for leaks. Let me know what you find.
Sep 28, 2014 | LG SteamWasher 3.6 Cu. Ft....
I have a LG front load washing machine, about 6 years old which leaks at the front bottom left side. I had General Appliance Inc. fix it. They said it was the pump system. $ 470 later I still have...
its not the pump, if it was you would have lots of water usually, a small leak could be a hose or hose clamp that needs adjusting check that first
Oct 19, 2011 | LG WM-2277HW Front Load Washer
Help ! We have an L G front Load washer model # WM2016CW that leaks soap out the front bottom of the dispenser. It is 2 years old and I have followed all the manufacturers instructions on using HE soaps...
You can remove the dispenser and place it in the dishwasher for easy cleaning.
I have included some notes on your washer and I have a service manual for you HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 07, 2011 | LG WM-2277HW Front Load Washer
It started leaking when filling with water...why?
I've had to replace the internal hose three times where the water connections are. It is a "Y" hose, that is not sturdy, and a defective design. I've had this washer for three years, and this keeps happening. If you look carfuilly, you'll find a hole at the "Y" junction.
Feb 22, 2010 | Malber P21 Front Load Washer
Water leaks on the floor,under washer. cleaned filter,but no help.
Hello there:
There are several hoses that run under the washing machine that go to different pumps that could be getting loose from the machine operation over time
so and alos hoses are subject to failure due to wear and tear
So what you are going to have to do is to remove the front lower panel and use a flashlite and look to see where the leak is coming from
and then once yo have found where the leak is coming from you may be able to tighten the hose clamp if it is that is leaking and hopefully not he hose itself. and if it is the hose it'self that is leaking have to replace the hose ok
Hope this is very helpful for you
Dec 18, 2009 | LG WM1812C Front Load Washer
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
