Question about Car Audio & Video
No display or sound but power to unit
When i wired my sony XR-C5120R into another car no display came up and controls were not working yet cd chnger was able to open and could hear mechanism moving inside stereo can u tell me what ive done wrong coz i'm at the end of my tether with the wretched thing!
KaeZoo
  • 156 Answers
SOURCE: in car audio
Hook the remote leads from your amplifiers to the blue/white wire at the back of the Sony head unit.
Posted on Mar 07, 2007
Eagleeyes
  • 199 Answers
hi sounds like you have the amps switching on via the aerial remote and not the amp remote. easy way to test this is to switch the AF or traffic function on your radio. if this cures the problem then you have the amp remote and aerial remote connected around the wrong way regards Mark www.carradiospares.co.uk
Posted on May 03, 2007
mixmaster
  • 626 Answers
SOURCE: wiring car sterio
Could not find your specific model.
But I found this on the Sony website.
9-pin wiring harness
16-pin wiring harness
Posted on Nov 25, 2007
SOURCE: can you tell me how
ok, for the kenwood models there is a metal clip on both sides of the cage, each side has one or sometimes 2 teeth that fit into the sides of the deck, picture enclosed, it should be able to slide in and "click" into place. hope that helps.
Posted on Apr 26, 2008
  • 4 Answers
SOURCE: Sony Cassette Car Stereo - 10 disc changer - XR-C5120R/XR-C5110R/xr-c4120
NEED TO REMOVE POWER FROM UNIT THERE SHOULD BE A BLACK CABLE THAT GOES IN TO CHANGER REMOVE IT WAIT 5 SEC AND INSTALL BACK LIKE IT WAS AND THIS WILL CUT ALL POWER TO UNIT AND WILL 50% FIX THE PROBLEM
LET ME KNOW
Posted on Jul 15, 2008
Need wiring diagram for sony xr-c8200.need to know what color wire is the power wire.
red is switched or ignition power, yellow is constant power, black is ground.
Feb 18, 2011 | Sony XR-C8200 CD Changer
Hi My sony cd changer in my car has very recently stopped poading CDs and comes up with an E-99 message on the the display, can you please advise what this could mean? Thanks
The E-99 error will come up if you try to play a CD to quickly after turning it on or loading. You will need to disconnect the power (red and yellow wires) from the harness (back of CD player) and leave it disconnected for sixty seconds. If that does not correct the problem then you will need to get the laser inside your unit re-aligned
Mar 08, 2010 | Sony XR-C5100 CD Changer
Car stereo removal
any good car stero shop in your area will do it for free!! (on the hopes you will come back later to purchase from them.
you may try a thin (pointed) wire coathanger on each side, it is simply a hook at the end that needs to be dis-lodged.
Thanks for using FixYa - a FixYa rating is appreciated for answering your question.
Mar 16, 2009 | Sony XR-5120 CD Changer
SONY XR-C450 FACEPLATE WON'T LIGHT UP
How do you solve the problem my face want light up
Nov 25, 2008 | Sony XR-C450 CD Changer
Sony XR-C350 Car Stereo - can't use cassette adapter for ipod!
For Sony radios you need an aux Bus adapter called the Sony XA 300. It works with the Bus IN RCA, and there whould also be another plug spot for the Bus power and signal interrupter. That is how the Sony knows to access that port.
Oct 31, 2008 | Car Audio & Video
LET ME KNOW
Jul 14, 2008 | Car Audio & Video
Wiring color code for xr-c5100
I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
Top row, left to right:
White - Front Left (+)
Green - Rear Left (+)
Purple - Rear Right (+)
Gray - Front Right (+)
Blue/White strip - AMP REMOTE (Max 0.3A)
Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
Red - Power (Accessory)
Black - Ground
Bottom Row, left ot right
White/Black - Front Left (-)
Green - Rear Left (-)
Purple - Rear Right (-)
Gray - Front Right (-)
BLANK
BLANK
BLANK
Yellow - Power (Battery)
One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
Important notes:
If there is no ACC power line in the car, do not connect the red lead.
Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
(Posn A is for normal use, with red line on ACC)
The RESET buttom should be pressed after installation, before initial use.
Hope this helps.
Jan 08, 2008 | Sony XR-C5100 CD Changer
In car audio
Dec 30, 2006 | Sony XR-4890 CD Changer
In car audio
Car Audio & Video Logo
207 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
