Im trying to check whether my router firewall is on! how do i access it?
I cant access my router how do i do it?
  • Mark Gough May 11, 2010
    what make and model of router do you have?
    President:
  • 1,865 Answers
1.Open your internet explorer.
2. Click on file, then open and type in 192.168.1.1
3. A window should come up asking for name and password
4. I need to know what router you have so i can tell you the default name and password
Posted on Apr 15, 2009
  • 64 Answers
In a browser try one of the following 192.168.0.1 ; 192.168.1.1 ; 192.168.100.1 ; 192.168.1.100.
If this helps, please rate me.
Im using dell laptop winxp, I alredy connected to wifi access yet cant access internet connections. Pls help. Thank you
You can try other options such as these
1. Try disabling or uninstalling your Firewall / Antivirus 2. Uninstall your Wireless Application and use the wireless zero configuration on your computer 3. Try resetting your router to its factory defaults 4. Try hooking up a ethernet cable to the router see if your getting internet access.
Jul 22, 2011 | Internet Computers & Internet
My router power light blingking and unable to connect router if i try to setup wizard to my pc..
make sure your routers setting are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection last resort ring your ISP internet sevice provider get them to check your modem for internet access online hope this helps
Apr 13, 2011 | Computers & Internet
No try to get on the internet
if you mean that you cant get the internet through your router
hope this helps
Jan 01, 2011 | Computers & Internet
Cant access internet banking
1. you could have a firewall issue in the the Windows Security (n check here first)
2. Then check your firewall allowances in the router itself.
to access you may have to use 192.162.0.1 or 192.168.1.1
to access the router through a web page.
user name ; usually "admin' then password "password"
this is default.
I hope this helps. Have great day!
Jul 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
Error code 80072745
From the Microsoft web site at: http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13931.entry?sa=240159924
December 11 Error: 80072745 If you are encountering the error code 80072745 when you sign into Messenger try the following: 1. If you are connected to the Internet through a router, remove the connection to the router. Then, directly attach the network or modem cable to the computer. This will help determine whether the issue is related to a firewall setting on the router. Try to sign in to Messenger after you connect to the Internet. If you can connect to Messenger after bypassing your router, the issue may be related to router settings. Try resetting your router (Note: This may revert your settings back to factory default settings and may delete all your custom settings.). Please contact your router manufacturer's Help documentation or customer support channels to determine how to reset your router or enable port 1863 through the router firewall. 2. If you are signing in from a corporate environment, contact the network administrator to determine whether port 1863 is being blocked inside the network.
3. If you have Zone Alarm with IM Security installed on the computer, turn off IM Security for Messenger: 3.a. Right-click the Zone Alarm icon in the notification area, and then open the Control Center.
3.b. Click IM Security or click Security to open the IM Security settings window.
3.c. Click the Main tab or the Status tab.
3.d. Slide the Protection Level slider to Off to turn off IM Security.
Note: This procedure will change the IM Security settings for any instant messaging programs that are installed on the computer.
3.e. Sign in to Messenger again to determine whether the issue is resolved.
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service.
Aug 15, 2009 | Microsoft Office Outlook 2003 for PC
Cant get online
might be a router issue, specifically the firewall. you might wanna click on network (ing) and select the router. See if you can manually add the ps3's address as a local access point on your router/ modem. you can access the ps3's ip address in system info, which i'm sure you know. maybe take the firewall down temporarily, by setting it to off, to see if this is blocking the ps3 from accessing the network. does the ps3 need any more configuring, vis a vis the network configuration? Do you need to subscribe to the PS network to access it? I don't have a PS3, but my psp works fine, as well as my 360. Try this and tell me if it works out, or if you need any other clarifications for arising issues. and remember to enable the firewall back up whether or not it works.
May 25, 2009 | Sony PlayStation® 3 (60 GB) Console
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Windows live messenger
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service. Hope that helps!
Apr 23, 2008 | Microsoft Office Outlook 2003 for PC
My WiFi problem
Please confirm the manufacturer and model for the router being used? The router in the heading of this message does not appear to have wireless capablity.
Secondly in terms of your sisters machine assuming it has an ethernet port have you tested it using the cable just to make sure there are no (software) firewall issues on her computer affecting access to access the internet.
Sorry I have no Nintendo DS knowledge specifically. I may try to research the issue after the router and laptop issues are resolved.
Are there any other wireless devices (computers) currently working correctly with your wireless router/access point?
Dec 15, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
David Payne
David Payne
