Chevrolet kalos blaupunkt radio removal problem
Own a chevrolet kalos with a factory fitted blaupunkt radio/cd. It has a problem of switching itself on. I have a radio/cd to replace it, but Im told by Blaupunkt there are no removal keys for to remove the stereo, and they can only suggest buying a new one..£115, which I dont want to do...and I still dont understand how a mechanic would get it out with no removal keys. I have tried all i can think of, other than take the car apart to get into the thing. Any help on getting this thing out would be appreciated.
Remove the secuirty panel from the front o f the unit.
with a small fine flat bladed screwdriver remove the two facia strips - one either side, CAREFULLY! they are on clips.
You should find four 10mm bolts holding the whole frame in, remove these and you may need to fit a subframe to re-fit your new unit.
Fit your new unit or frame into place, replace the bolts - don't over tightem them - and the trim.
Fit your new unit - Happy motoring!
Posted on Jun 04, 2009
I have a Seat Altea and need to know if I will encounter any CPU or alarm problems if I remove the factory fitted Blaupunkt radio entirely from the vehicle?
Radio's don't affect the security. But if installing another factory radio, it has to be programmed to your car. After market radios don't. If using an after market one, you will loose some chimes, like door,key,lights, ect...
Sep 03, 2016 | 2008 Seat Altea 2.0
How can i reset car radio blaupunkt 300 rds vauxhall astra it is set to safe
Switch on using the ON and AS buttons pressed together
Then LEAVE SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself
Once reset , enter the correct code
Press AS and your radio should work
Jan 20, 2011 | Blaupunkt Chicago IVDM-7002 Radio/CD/DVD...
How do I remove the Blaupunkt CD/radio from a 2007 Chevrolet Kalos. I wish to replace it with an updated unit
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire
coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys
or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These
can be unscrewed using the appropriate size of Allen key.
May 28, 2010 | Car Audio & Video
Blaupunkt GMBA radio to boxer van discnected to
The instructions should be one of these
http://www.radio-code.co.uk/post_in_radio_code_model_selection.php?m=Blaupunkt&search=peugeot&Submit=Search
Oct 16, 2009 | Blaupunkt Car Audio & Video
I need a radio/cd, that would work with my steering wheel control
im sorry but i must be blunt the people who installed your deck were lazy instead look up factory wheel control module on google there is a system that (as long as the deck has any type of remote) allows you to hook this up run a small wire with a out put laser to the front of your deck acting as a remote control if this infact is not the case use crutchfield.com enter in your car information look threw the decks when you find one you like look in eccesorys if its not an option it wont be there :) honestly the jvd avx 820 is amazing for the price check it out it will work with your controls
Sep 24, 2009 | Blaupunkt Alicante CD32 CD Player
Factory Fitted CD player. 1994 Jaguar XJ6
i think there may be a fuse located on one of the wires thats attached to the radio itself, you will have to pull the radio to check it
Jun 17, 2009 | 1994 Jaguar XJ6
Fiat cd changer wont keep its code inthe memory
The radio requires TWO battery feeds.
One is a permanent battery feeding the code and station memory
The other is the main one  via the Ignition Switch
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt antenna connection !
Yes - adapters are available in stores & online. Try here:
http://www.bluespot.co.uk/install.asp
Mar 13, 2009 | Blaupunkt Hamburg MP57 CD Receiver CD...
2,131 people viewed this question
 Grubhead
Grubhead
