Question about NetGear RangeMax WPN824 Router
Re-Connectivity to Comcast Modem
A year ago I set up a Netgear WPN824 router with a Comcast modem. Recently, Comcast did something and the router stopped working. I can connect directly to the Comcast Modem and I do get throughput. Comcast refuses to help saying the router is defective. I connected the router to another cable modem from a different ISP and everything worked from the "get-go". So what's up with the Comcast Modem?
    Genius:
  • 1,268 Answers
All you need to do is "MAC ADDRESS CLONING". Access the router's setup page and look for MAC Clone settings. Enable that and clone the mac address of your main PC. After that, perform a power cycle. Turn off the router then the modem. Wait for 30 seconds then power on the modem first, wait for all the lights to go solid then power on the router. That should do it.
Posted on Apr 15, 2009
I recently purchased a Netgear N600 Wireless router connected to my Comcast Motorola Surfboard SB5120 modem. I have a Comcast plan of 20 Mbps but through www.speedtest.net am consistently getting 8 Mbps...
I think its the modem that you need to upgrade. Comcast is already running on DOCSIS 3.0 system. The SB5120 modem that you have is a DOCSIS 2.0 modem. You may need to have your modem replaced with a DOCSIS 3.0 modem like the Motorola SB6120.
Aug 31, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My new/replacement modem: Motorola 2210-02, will not work with my old Netgear WPN824. I've tried everything I can think of, and I do not want to buy a new router. Any suggestions??? -Terru
If the modem and the router both want to be on 192.168.1.1, try setting the router to go to 192.168.2.1, or see if your ISP can provide you instructions for turning the router portion of the motorola off (Bridging the modem is the technical term). At that point they may be able to provide you with how to setup the router to work on your connection as the primary connection holder.
Jun 25, 2011 | NetGear RangeMax WPN824 Router
WPN824 Transmitting Signal, no internet.
As a last resort, you can reset your router by holding down the reset button in the back. It doesn't sound like this will fix the problem however. Purchasing a new router shouldn't be necessary, as most if not all Netgear routers come with a 1 year warranty standard.
Aug 02, 2010 | NetGear RangeMax WPN824 Router
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 24, 2010 | NetGear RangeMax WPN824 Router
I have been trying to configure my Netgear WPN824 for so very long, and nothing has worked. I posted on here once before, and I went through a step-by-step list of how to set it up, and it seemed like it...
Are you trying to set up router ?
Mar 12, 2010 | NetGear RangeMax WPN824 Router
I cannnot download the cd for my WPN824 because I I have windows 2007
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 19, 2009 | NetGear RangeMax WPN824 Router
I'm trying to connect a netgear wpn 824 to a comcast router with windows 7
You are trying to set up the wireless router with the comcast modem, right ?
You can set up the router manually , without the disc.
Make sure that your computer is able to go online when connected to the comcast modem only.
If you have the router working already then you just need to add a computer to the network.
Click Here for step by step solution
Oct 27, 2009 | NetGear RangeMax WPN824 Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax WPN824 Router Logo
461 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
