Sharp AR-BC320 All-In-One Led Printer Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a F2-41 code. What does this code mean?
I have a code: F2-41 on my Sharp AR-BC320 copier/printer. Can you tell me what this means?
amir hamza
Level 2:
  • Sharp Expert 318 Answers
  • Posted on Sep 20, 2010
amir hamza
Sharp Expert
Level 2:
Answers
318
Questions
Helped
188806
Points
694
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
  • Michelle
    Michelle Dec 29, 2014
    So how do you fix this problem???
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
What is code F1-03 mean for a Sharp AR-BC320?
Check the sorter whether its well connected and check its motors and sensors.
3helpful
AR BC320 H5-01 error Need to know how to clear it
# * C * in fast sequence. Then enter simulation 14 and press start button. Hit yes to confirm and then the copier will reboot.
How do i clear a F9-00 code for the sharp ar-bc320 copier?
Put the machine in test mode with the following key sequence:
P - * - C - *
then, 14-Start ... Execute ... Yes
CA to reboot the machine. For good measure, shut the power off, wait, and turn it on.
PS. - Get your copier on its' own outlet and share it with Nothing!!
5helpful
2answers
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
2helpful
4answers
Looking for a reset code for sharp ar-bc320
The default key operator access code on that machine is 00000
with this code you can enter network settings and change ip and subnetmask to your new requirements.
If this doesnt work you can get keyop password by entering simulation mode and get service report which has user code on it.
Copier Sharp AR BC320
i'd try consumer reports or Cnet.com for reviews, and that might let you know more about it..
got backup for that computer?
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
