Question about Campbell Hausfeld Air Tools & Compressors
6 gallon Husky air compressor won't start
Have only used this item 3 times since purchased in Oct 08. I plugged it in, started it, it ran for a few seconds and it shut off. Now it will not start at all. Is there an internal fuse that may have blown?
  • 234 Answers
There are a few things that may have happened.
  1. Motor overheated and thermal cutoff switch was tripped. Usually this is a red button on the back of the motor. Press it and it may solve the problem
  2. Motor did not start fast enough and it burned out your starting capacitor. This us usually located on the top of the motor under a dome shaped cover. If replacing these you must match up the mfd rating of the original and the replacement capacitor(s)
Air compressors have a fairly high draw and you should be sure that it has a proper electrical supply to it. Too small of a cord can cause the two above problems.
Also make sure that your pump is not seizing up.
Posted on Apr 15, 2009
Air compressor cannot spin up with pressure in tank sometimes
There is an unloader valve and a check valve on the discharge side of the pump. The check valve is not holding and the unloader is not dumping the pressure so the compressor cannot start. Since it is new, you may want to take it back. If not you are going to be replacing parts.
Mar 10, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Compressor won't come on
if you have power, the pressure switch is stuck or bad.
Jan 11, 2013 | Coleman Powermate 11 Gallon Air Compressor
Husky pancake compressor won't fill
have you checked the ring and cylider or the valves?
Jan 02, 2013 | Stanley FactoryReconditioned Bostitch...
Have mod.# wL651004aj put new piston and ring kit in still does not build air pressure nee help
I would suggest checking the valves . Make sure they are good,no trash ,seating properly. other items to look at include, head gasket,installed correctly? air filter plugged or inlet blocked with something
Aug 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I've owned the air compressor for 6 years, but in that time I have only used it less than 2 hours. Recently, I plugged the compressor into the wall plug, and it ran for a few minutes, but then the...
The switch for the starting winding probably has failed shut drawing current through capacitor and the winding even though unit has started. There is usually a centrifugal actuaated switch with contacts that open when motor is near full speed.
Jun 01, 2011 | Clarke Power Products Inc AC2001 2HP 4...
We just purchased a Husky 60 gallon air compressor that uses 220, but is not wired with a cord. We have 4 wires coming from our sub panel, 3 wires in the cord we're attaching, and 3 wires coming from the...
The red and black are the hot legs of the connection. the white is the neutral, and the green is the ground. the ground and the neutral in your cae can be pigtailed. you will need to know what the starting and run amperage is in order to determine the wire size. My guess would be a 12-3 with ground would be adequate with a 25 amp breaker.
Oct 17, 2010 | Garden
Husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
Sep 03, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
1,363 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
