Question about HP Compaq Presario C502US Notebook
My computer turns on just fine but i cant get it to open or load windows
  • Jerry Purvis May 11, 2010
    Where does the computer stop loading?
My computer turns on fine, I hear the windows sound load, my desktop picture loads, but no icons load. I believe this happened when I manually turned off computer in hurry. I got one message indicating the...
1- run the windows in Safe Mode.
2- enter the windows and see the icons are shown or not.
3- if icons didn't load press "Ctrl+alt+delete" for using task manger.
then choose "new task" from "File" and type "EXPLORER" in "open".\
please rate
Jan 17, 2011 | Compaq Presario C552US Notebook PC
I have a 5yr old Dell w/XP and use IE and Firefox. Lately I have been unable to access my control panel. I click on start then click on control panel but all I get is the ever aggravating hourglass and...
Here are a couple suggestions. 1.) You can run windows system restore back to a date when you knew your system was running fine.
If that fail to fix your problem than, turn off windows restore. You do not need to enter control panel to do this as long as you have My Computer icon sitting on your desktop. (IF not, right click once on a clear spot on your desktop). From the pop-up window left click once on properties.
Display Properties will open. Click on the Desktop tab. Than click on the Customize Desktop button. Desktop Items will open. Make sure there is a check mark in the box next to, My Computer. That will add the My Computer icon to your desktop.
Right click on it once & from the pop-up window slide to & left click on properties. Click on system restore tab.
Reason for this: if your system has a virus or Trojan it will copy its self into system restore. Turning it off prevents this. 2.) Run your antivirus software & check for issues. 3.) Download the free software named ccleaner; http://www.filehippo.com/download_ccleaner/ & install it. Run the standard cleaner. Than click on the registry icon and scan for issues. This will remove double registry keys & corrupt keys. Than restart your system. When windows finishes loading click on update windows from the start button. Check for hardware & software updates & install em'. (If any). When you feel everything is running correctly you can re-enable windows system restore & create a restore point.
If everything above did not fix your problem you may have no choice but to repair windows. Load your windows restore CD into your CD-ROM drive and boot to it. Running Dell's restore should repair windows. Most of your data should be fine. Some programs may need to be reinstalled.
Cheers'
Mike
Jul 18, 2010 | Computers & Internet
Vaio PCV-W30- The computer stops at the blue Windows XP screen and will not load Windows. The DVD drive will not open. Cant do a restore. Any suggestions?
Should be a small hole in DVD drive lid.
Turn off computer and carefully insert a straightened paper clip.
Gently push & the lid should pop out.
Then you can open the drive & use the windows cd to repair/restore
May 12, 2010 | Sony VAIO PCV-W30 PC Desktop
Keeps freezing after loading windows xp, won't allow me to use any apps or open anything
if you cant afford to get it repaired, then check the processor, hdd, ram slots to ensure that they are all in their fixed possitions,
the problem may be that a module of ram has come loose or your processor has, if they haven't then get yourself a digital multimeter and learn about computer electronics,, although buying a new computer maybe the quickest option.....
May 31, 2009 | Compaq tc4400 Tablet PC
It starts up fine until a blue screen pops up
hi
i think one of the drivers are the culprit. heres what you should do:
open your system unit and remove all the pci cards except the vga card. and turn on the computer.if it starts fine, then turn it off and hook each card one by one.
hope this helps
Kind regards
RAhL_hunk
Mar 06, 2009 | Microsoft Windows 2000 for PC
Laptop wont turn on properly
A vital component that windows requires to run is corrupted. To fix it, you need the OS disc
In Windows Vista, there is usually a second partion on the harddrive that you can load by pressing F8 (or F10 depending on your system) and selecting the repair your computer option (depending on your manufacturer, you might need to input a password, after that choose the repair your computer option or solve startup problems
In Windows XP load the disc and open the recovery manager.
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
MP4 Missil not working
I used real player to get songs on my missil sd-2415 MP4 player. You need to use the driver disk it came with to get it to work. Once you've used the driver you should be able to just plug your player into the computer via the USB cord, open real player Version 11, compatible with Windows XP, although the driver says win 98, it worked fine with my Windows Xp. Nothing really comes up once thr driver has been downloaded, so don't get confused, just follow the driver install wizard and it should be fine. Then on Real player just click on removable disk or player not sure of the exact wording but it's removable somthing the just drag and drop or click to move music from your playlist onto the player.
I had to fiddle around with this player a bit because the instructions are VERY LIMITED! that's putting it mildy but hey it is what it is. This little player is quite neat once you figure out it's little quirks! Good luck!
Dec 26, 2008 | Network Computing Devices (NSH800S/A)...
My laptop freezes in the middle of doing anything therefore I cant get anything done.
run a spyware removal program on the computer and see if that helps. also what is the make and model of the computer as well as the operating system you are using
Dec 16, 2008 | Acer TravelMate 2300 Notebook
HP Compaq Presario C502US Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
