Getting a code SC390 on my Ricoh Aficio 1045 - Office Equipment & Supplies
  • kduke900 Apr 16, 2009
    Definately a code SC390. making lots of copies would stop and give code and say to turn off and on main power, if code comes up again call for service. later in the day we did get a low toner light pop on. If I replace the toner do you think it will stop the code or should I have the repairman come out?
  • keith640 May 11, 2010
    Could you please check that code again. I cannot find it listed in my tech guide. The closest error listed is SC391 which indicates a Toner density sensor error.
  • 23 Answers
I call my tech support. The problem does have to do with an abnormal reading of the Toner density sensor.
Adding toner may be just the ticket to fix the problem.
Posted on Apr 16, 2009
  • 162 Answers
Can be damaged the paddle roller of the development unit Change.
Part No AD03 8078 Paddle
Posted on Oct 21, 2009
Ricoh aficio 1035 copier, functioal problem SC390
The TD sensor could be bad. But more than likely you need to replace the dev material and the drum and charge roller
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 sc321 code
laser code: polygon mirror not spinning in laser will need to replace it.
Jan 14, 2014 | Ricoh Aficio 1035 Copier
How clear ricoh Aficio 1045 code sc321
IM RICOH COPIER TECHNICIAN AND I HATE THAT CODE 321, 322. CHECH THE LASER UNIT
Jan 14, 2014 | Ricoh Aficio 450 Copier
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 03, 2011 | Ricoh Office Equipment & Supplies
Sc390
SC390: TD sensor error
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
468 people viewed this question
k24674
jasbo
jasbo
