Cant enter simulation in sharp ar m207
I prees clear key.interrupt .0 .interrupt and the machine doesnot go off
  • 62 Answers
# interrupt clear interrupt
Posted on Nov 12, 2007
  • 163 Answers
DEAR SIR YOU CAN TRY ALL SHARP COPIER IN THESE MODE,C INTERRUPT 0 INTERRUPT, C O O C, HASH INTERRUPT C INTERRUPT ,I M SURE ANY OF THESE MODE YOU CAN ENTER IN P-ROGRAMING
Posted on Sep 16, 2007
  • 30 Answers
Try clear, interrupt, zero, interrupt. That works for most of the digital machines.
Posted on Sep 15, 2007
  • 163 Answers
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
    New Friend:
  • 3 Answers
Try # * Clear *, it will ask you to enter simulation code. Type 14 then press start. Then press 1 for yes and start again. The machine should then restart and the error code should be cleared.
Posted on Apr 24, 2010
SOURCE:
HOW CAN i CLEAR h4?
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 04, 2015 | Sharp AR-M160 Laser Printer
How do i remove or cancel error message h4 on sharp digital ar-153e copier
OR
Oct 23, 2015 | Sharp Office Equipment & Supplies
HOW DO I RESOLVE H - 4 ERROR ON MY AR-5320E SHARP PHOTOCOPYING MACHINE?
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Apr 30, 2015 | Sharp Office Equipment & Supplies
Have Sharp - AR-5516 and H5 error blinking on the screen
OR
Mar 28, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
Mar 20, 2015 | Sharp Office Equipment & Supplies
I have a sharp AR M256 we were getting an error toner replenishment in progress. CAll FOR SERVICE. CODE H4-21
sir
OR
Mar 09, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
How to reset the Maintenance indicator sign in SHARP AR 5618
OR
When the
Dec 09, 2012 | Sharp AR-5320 Black and White Copier
HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS CHANGED. CODE H3-00 STILL APPEARS.
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Nov 04, 2009 | Sharp AR-5320 Black and White Copier
My Copier is showing 0-8 problem and is not working how to fix it?
Try reset the error by following this step :
["#" key] [Interrupt key] [CLEAR key] [Interrupt key] [1] [4]
[START key]
The machine will be reset and hopefully your trouble too.
When the CLEAR ALL key is pressed, the simulation mode is cancelled.
May 26, 2009 | Sharp Office Equipment & Supplies
945 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
