SOURCE: Panasonic Lumix DCM FS5 camera. Inbuilt Memory
delete the pictures (you should be able to upload them first)
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
SOURCE: DMC-FX55 memory problem
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
