Broken Laptop hinges
I have broken both of the hinges on a Phillips x72 laptop brought from the DSG retail group in 2008. The laptop appears to be a re branded Twin head machine as Phillips don't make their own, but I dont appear to be able to locate the parts to repair this. Can anyone help by either telling me the original twinhead model number, or by finding me a source of parts?
  • 30 Answers
I had the same issue with my X72. The hinges of a Advent qrc430 will fit this model, As will most other parts off the advent.
Regards Mike
Posted on Apr 29, 2009
Mike, I have the same problem with an X72 but can't get hold of hinges from either of these models anywhere! Where did you get the hinges please - or are there any other models that will fit?
Thanks, Rachel
Posted on Nov 13, 2009
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
HP Pavilion ZE 2315 laptop with a black screen. First the screen image locked and now the screen will not even come on. Was told it's the GPU. How can I fix this?
Remove the screen and look for broken wire/s where the screen part hinges to the rest of the laptop. I repaired this very same problem last week. Provided the screen is not damaged, this may be your problem. Just remove the small, circular, rubber pads that hide the Phillips head screws (also provides for soft closings )and remove the screws. Use your fingers to pry off the plastic piece around the screen. Inspect the wires leading from the keyboard to the screen, and if broken (probably in the hinged area), solder and tape it
Aug 27, 2013 | Computers & Internet
The right hinge on the monitor is broken and the the monitor does not work at all. It appears the hinge locks on two hoop-like catches, and one of the two is broken. Thank you
hello your screen will not work because the wirering that comes from the laptop to the monitor has either broken or came away from its plug it would be best to leave it into a repair shop i hope this helps you goodluck
Mar 30, 2011 | Averatec AV7170-EC1 Notebook
My laptop is very slow how can I clean it up Phillips X72
You can clean it by uninstalling unwanted programs and also deleting of files that are not important on the computer.
I hope this solution is helpful.
Sep 26, 2010 | Computers & Internet
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Jun 01, 2009 | HP Computers & Internet
Laptop hinge broken
You may be able to purchase parts from :-
www.lcdparts.net
Also from
www.ccflsurplus.com
May 27, 2009 | HP Computers & Internet
Advent 8315 Laptop
One of the best sources for these types of things is online at a site called newegg.com. You can search based on the Manufacturer and model number of your Laptop. If that fails you try the Manufacturers website, they will sometimes list where replacements can be purchased or well on themselves.
May 20, 2008 | Recoton Advent Advent Q2035A 20" TV
Monitor dark; hinges broken
He may have damaged the inverter or left the cables disconnected from the backlights. The inverter supplies the required voltage to the LCD Back lights.
Mar 31, 2008 | Toshiba Satellite A25-S207 Notebook
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
