Question about Nokia 6288 Cellular Phone
Where does the battery go?
I just received my new phone upgrade and the instructions to fit the battery dont seem to match the phone itself! Any ideas please?
Contact ur retialer!!!!!!!!!
Posted on Oct 13, 2007
SOURCE:
I have a ZTE MAJESTY W STRAIGHT TALK AND THE BATTERY SEEMS TO NOT WANT TO STAY CHARGED AND CUTS OFF AND THEY SAID THEY DONT HAVE AN EXTENDED BATTERY THEY WOULD SEND A REFURBISHED PHONE I DONT THINK THATS...
It's simple, a good innovator technician near you can assist. Just buy a better battery that can fit Ito the old battery slot and let the old casing be oped and the new batt casing removed. Resolver the terminals and insulate them before inserting old case now use it and forget the refurbished phone.
Jul 19, 2014 | Cell Phones
I have a riva 67 balanced flue gas fire. The duracell batterys last 2 weeks before the fire turns itself off. Fit new batterys its fine.I have replaced gas valve, control box and battery box. Wiring seems...
check all wiring carefully cause i have ran into cases where i find the smallest piece of wire rubbed through the insulation and causes random shorts
Oct 22, 2013 | Heating & Cooling
Hye,first of all sorry for my english.I have Samsung LEDTV LCD UE46C8000XP,and I download a newest software from samsung.com site ( T-VALDEUC-3001.1 ) and tell now I have a problem with 3D movies! Can I...
You can't I'm afraid. There is no mechanism for reverting to older versions of the firmware and this upgrade (3001.1) destroys your TV. I have phoned and e-mail samsung and their only resolution to this is "have a new moterboard fitted".
Unfortunatley if you search the AV Forums on the web you will see thousands of people have fallen into this trap and Samsang dont seem to care. Try contacting them directly through samsung.com
Anyone else reading this should avoid purchasing Samung products and CERTAINLY don't upgrade the firmware if you already have one. Unfortunately Samsung dont seem to understand the concept of customer care.
Sorry dj_mrcina, this probably isn't what you want ot hear but your only options are: hope they release a patch with a version of 3001.2 or above : get a new motherboard fitted (Samsung will pay for this is you call them) : Stop watching 3D.
Nov 03, 2010 | Samsung Computers & Internet
I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Apr 14, 2010 | Seiko Mantel Clock
Phone freeze
first try the phone using another battery, do tyr changing the unit battery make it sure it was fully charged. iy seems that you have a weak or faulty battery pack now.
Hope this initial info/idea helps
May 30, 2009 | Samsung Cell Phones
Battery installation
new battery should be fairly close physically to the original. Terminals must match, especially if cables don't reach!!! Bring it back and get the right one. If you cannot for some reason, you can get longer cables and remove the lip on the battery tray in most cases to make it fit. But, do you really want to do that???
Jan 08, 2009 | 1990 Toyota 4Runner
X820
Try formatting or resetting it once!!!
May 16, 2008 | Samsung X820 Cellular Phone
My nokia n95 switches itself off
when a nokia n95 switches off and on, all you have to do is put a sim that doesnt work anymore then you have to switch the n95 on and wait for 30 minutes, then the n95 will stop from on and off, the laguage will be set to france mode..
Apr 12, 2008 | Nokia N95 Cellular Phone
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Nokia 6288 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
