Question about Panasonic Televison & Video
Dear Helper, Cannot follow instruction of ''Press TIMER Button to start timer recording!'' after leaving the ''schedule'' programming. There is no such ''Timer'' button on the remote control. Thanks New user Lotus
  • 2 more comments
  • anyan Apr 15, 2009
    Model: Panasonic DMR-ES10 DVD Recorder
    Remote: DVD/TV - N2QAKB000055
  • chris May 11, 2010
    try this link sorry should have been in prior message http://service.us.panasonic.com/OPERMANP...
    it appears to be tied into how long or quality of recordring look on page 15,17 and 32 hope this helps good luck!
    what model?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
It is probably a "soft" key. Look very closely (normally marked in red) to see if there is a marking above/below one of the keys. If still stuck, what make/model of recorder do you have?
Posted on Apr 21, 2009
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
New intermatic timer installed. I can turn on manually and it will turn off at designated time but will not prgress to turn on automatically.
If display shows, and timer turns lights on-off with manual override, then timer is wired correctly, and battery is good.
If timer will not turn ON at scheduled time, but turns OFF correctly, then best suspect is the programming.
Open following link for ST01C programming steps.
http://waterheatertimer.org/ST01C-program.html
Program1 is ON
Program2 is OFF
Program3 is ON
Program4 is OFF, etc
Review your schedule: Press Mode button until PGM starts flashing, and then press ON-OFF button until 01 starts flashing.
If Program1 cannot be set for some reason, then set your ON schedule on Program3 and ignore Program1. The timer does not mind if you have OFF set on Program2 and ON set on Program3 or Program5 or Program7 etc.
If you have multiple programs, for example different ON-OFF times for each day, then check for scheduling conflicts that will cause timer not to function as expected.
If timer is defective, contact seller about 1-year warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do you delete a program that is mistakenly added to the record every episode mode
The easiest way I know is to press menu, then daily schedule. Find the program in question in your list. Click on that program and you will se a window "timers", click on that and you will see "delete", click on that. then you can reset your program to record the way you want. You can also follow the same proceedure, click menu, then daily schedule, then click on "timers". Scroll to the timer you want to delete, click on it, then click on delete.
May 02, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Techintion setup DVR to record speed channel daily at 7 pm now every night at 7 the channel changes to speed channel how do I stop it?
florami
The following is instructions for deleting timers from your receiver.
Turn your TV on. Press your DVR button on your DISH remote 2 times. This will bring up My Recordings on your TV. Select the Schedule button on the right of the screen. This will take you to the Daily Schedule screen. Select the Timers button on the right. You will be on the Timers List screen. Press and release the Left Arrow button on the remote to move the cursor into the Timers List box. Select the timer you want to remove. After pressing select on the remote, there is a button on the right, Delete. Select the Delete button and it will ask you if you are sure you want to delete the timer. Select Yes. You will need to follow those steps to delete all timers you do not want. As you delete timers, you will not see those timers on the Timers List or the Daily Schedule anymore. I hope this helps.
Ray Calo
DISH Network
Mar 04, 2011 | DISH Network ViP622 DVR DTV Receiver /...
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual...
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
Jan 21, 2011 | DISH Network DVR 510 DTV Receiver /...
I have a Woods 24 hours indoor lighting timer. I have followed the instructions provided with the timer, but lamp won't come on. Can someone please provide EXACT step by step instructions. Thank you
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
Oct 14, 2010 | Woods Industries 59377 Indoor Digital...
Just hooked up my new Magnavox DV220MW9 DVD Player ? VCR Recorder. I was able to set the time and a vcr timer program but now I can't switch the source. It now comes on as the DVD but neither the remote...
You need to release the timer to access the VCR. Press the Timer Set button on the remote or the Stop/Eject button on the recorder. Then press the VCR button.
Please note: the scheduled recording will not run as programmed unless you press the Timer Set on the remote again. (The timer locks the VCR until the scheduled ON time.) The DVD player is controlled separately and becomes the default unit.
I hope this helps.
Oct 04, 2010 | Philips Magnavox DVD/VCR Dual Player
Dish DVR recording shows that haven't been programmed to record
This may be caused by as many as three variables.
The first would be that if your neighbor has Dish Network and they have their TV2 near yours it could be picking up their recording preferences. This would create a recording specific to let's say MONSTER TRUCKS.
The next is if you notice MONSTER TRUCKS when trying to view an intended recording at the beginniong or end of the desired recording. This can occur if the start time an end time for your recordings have been set to begin before your intended recording and end after the intended program completed. You can edit this by pressing the DVR button, my recordings, schedule, timers, pick a recording from the list and press select, now press options and you will see the timer options which will allow you to manipulate the start early time and end late time among other things.
Lastly is that your program guide is out of date or the guide is totally errant. Unplug the receiver from the wall for a minute and repower it. This will force the system to update itself if it is not intefered with during this process. If after this procedure the same issue is occurring and the guide says the program you want recorded but retrurns an unwanted one then the guide is corrupted on the Dish Network side and will be repaired as soon as possible.
I hope this assists you. Thanks fornusing Fix Ya.
Jun 20, 2010 | DISH Network ViP722 DTV Receiver /...
How do I cancel program.
britstew2,
It sounds like you have timers setup to record on the 625 receiver. To delete the timers, press the DVR button on your DISH remote 2 times. This brings up the "My Recordings" screen on the TV. On the right side of the screen are several buttons. Move to the "Schedule" button and press select. This takes you to all the timers on the receiver. Go to the first timer you want to delete and then press select on the remote. Now you are on the "Timer Event" screen. Move to the button "Timers" and press select. Now you are at "Timer Schedule". Move to the button "Delete" and press select. This will delete that timer. You need to do these steps for all timers you want to delete. I hope this helps.
Ray Calo
DISH Network
May 27, 2010 | DISH Network DVR-625 DTV Receiver /...
Every program scheduled to record starts and ends five minutes early? So the end of the preceding program is recorded and the end of the selected program is cut off.
BigBillO,
One of the options for the DVR recordings is starting and ending before the program starts and ends. You can change this setting to your preference. To change , press the DVR button 2 times on your DISH remote. This will bring up the "My Recordings" screen on your TV. Go to "Schedule" button on the right side of the screen. Press select. You should be on the "Daily Schedule" screen. Go to "Timers" button on the right of the screen. Press select. You are now on the "Timers List" screen. Select one of the programs scheduled to be recorded and press "Select". You are now on the "Timer Schedule" screen. Go to "Options" button and press select. You are now on the "Timer Options" screen. This is the screen you can set your preference for the "start early" and "stop late" settings. Be sure to select the "Set as System Default" if you want to apply this setting to all your recordings. I hope this helps.
Ray Calo
DISH Network
Mar 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
