Question about HP LaserJet 3600n Printer
HP3600n printer will not work. Will not switch on but was working fine previously.
  • 1 more comment
  • p_taylor1 Apr 16, 2009
    No error codes or problems with the printer. It was working fine at the end of the day and when I went to switch it on the following morning it was dead.
    NO.
  • Maurice B Thomas
    Maurice B Thomas May 11, 2010
    So, you don't remember any error codes while the system worked?
  • 371 Answers
You're gonna hate me for asking this, but is it possible that power was
removed from the printer during an overnight cleaning period?
Posted on Apr 16, 2009
  • Maurice B Thomas
    Maurice B Thomas Apr 17, 2009
    Ok, then if no person or persons unknown had any access to a machine
    that you used successfully the night before it's malfunction became
    apparent to you, and it is fully powered, with no error codes, and it is full
    of paper and toner and other consumables, such as the fuser, and drum
    and it simply will not work to the extent of responding to a request for power
    up, then the only possibility is that your printer has reached the end of its
    duty cycle, in terms of its paper throughput.
    The duty cycle for this printer is 50K sheets/month but the recommended
    throughput is only 1-5K sheets per month.
    A service call is mandatory.
My hp3600n makes a grinding sound at start and the printout always has gray verticle smudges on it
If you run the PQ troubleshooting pages you will likely find that your black cartridge is faulty. Sounds like the drum is dragging.
Aug 02, 2015 | HP LaserJet 3600n Printer
How to change a HP3600N printer online?
How to change the printer? Bring a diaper bag.
Jul 11, 2014 | HP LaserJet 3600n Printer
Hp3600n getting magenta line down left side of page. Already replace toner cartridge which correct problem but then returned.
remove toner, shake and very well, then try again....
Let me know if this doesn't help.
Regards.
Sep 16, 2011 | HP LaserJet 3600n Printer
Hp3600n is stating that the fuser is hot what do I do
you either need to buy a replacement fuser assembly or a thermister for this unit the install is hard but it might be worth fixing due to the cost of the unit,
Jan 27, 2010 | HP Color LaserJet 2600n Printer
Have HP3600n over just 1year. Having trouble after startup gets stuck in calibration and won't go any further... any thoughts? Have tried cold reboot w/all unplugged several times...Mike
Start by removing the formatter. Have paper in tray 2.
Print an engine test. You should see repeating lines of cyan, magenta, black and yellow. If any of the colors are missing - run the Disable Cartridge Check. Run the engine test again with the previously missing color in another slot. If that color fails again, replace it. If the issue stays with the slot replace the laser scanner. If the engine test is good now, install a new formatter, power up and see if the calibration hang is gone.
Jan 26, 2010 | HP LaserJet 3600n Printer
We can not print the green color in my graphics
Get new cartridges. Refills only work a few times then the jets then to dry up.
Apr 28, 2009 | Office Equipment & Supplies
HP3600N color fade
It is using the colours to make the grey and the proportion is not correct. Do a calibration.
Dec 23, 2008 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
177 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
