Question about Neovo F 415 (Black) 15" LCD Monitor
Check video cable keeps reading and go off, but the power is still on
Montoir keeps reading. check video cable. an screen goes blank, but the power is still on
  • 73 Answers
The screen on most monitors will go black if the cable connecting them to a device is lose or disconnected altogether. try the cables in the back the ones other then power cable
Posted on Apr 15, 2009
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
Toshiba laptop pas409e-d screen is black
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Causes a Computer Monitor to Go Blank b> While a blank screen may be caused by a general power outage, more often it's a problem with the screen itself. It could be a loose video or power cable going to the monitor. If that's the case, you can get the screen working again and be back in business in a few minutes. b> Power Problems All the power might be off due to a bad outlet, switch, fuse, or circuit breaker. If you hear no sound coming from the computer and its power light is off, check the power connection and breaker or fuse. Video Cable Many times the cause of monitor blackouts is a loose video cable connection. This might happen if you move the monitor or the cable. The video cable runs from the back of the computer to the monitor. It has a multi-pin connector on each end and both of them screw down securely. If the screws aren't tight, either connector could become loose. If that happens, the video signal could stop suddenly and make the picture go blank. Check both ends of the connector to make sure they're firmly seated and the screws are tight. The cable itself might be bad.This is unlikely, but possible. b> Display Power The monitor must have power. If the power light isn't lit on the monitor, it may have been turned off or become unplugged. Press the power button to make sure it wasn't accidentally turned off. Make sure the monitor is plugged in. If it's connected to a power strip, check that the power strip is on. If that checks out, unplug the monitor and try a different outlet. Power strip sockets can sometimes fail. Flat-screen monitors may have a power-brick-style adapter. It, too, has connectors. Follow the power cable from the monitor's power plug back to the monitor. About halfway up you'll find a thick rectangular plastic brick. The power goes into a modular-style equipment socket. This can become loose. Follow the wire the rest of the way to the monitor. It connects to the back of the screen with a small round plug. Check that it's firmly plugged in. If everything's plugged in right and the power light on the monitor's still off, the power brick might be bad. b> Video Card Some computers have a separate video card inside. It may come loose and cause a blank screen. If this is the case, open the computer and inspect the video card. Sometimes removing and reseating the card will fix the problem. If it has to be replaced, most video cards are not expensive.
b>
Feb 15, 2013 | Computers & Internet
My acer monitor come on and screen go blank
Step 1:
Feb 15, 2013 | Acer Computers & Internet
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
When i cut on my monitor it goes out after a few seconds.The power is still on but it goes blank. Also when its on, the whole screen is a pink tint.my video card is fine i have duel monitors.but my wide...
tried self test on monitor unplug the data cable from the tower and turn on the monitor only ans see if the problem persist then u need to change the monitor if it works fine uninstall the video drivers and reinstall it or try onboard display if possible
Aug 17, 2009 | Proview PL19Wb Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell Desktop, wont power up..monitor goes blank
Remove the cable. Keep pressing F8 while you power on the system and choose safe mode, press enter. Screen will roll up a few pages and stops for a while. wait a few minutes. windows will start in safe mode Scan for viruses. Restart. It is a virus problem
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Neovo F 415 (Black) 15" LCD Monitor Logo
220 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
