Question about Toshiba 32A35 32" TV
Strange volume troubles
First, the remote stopped working, new batteries, nothing... All of a sudden, the volume bars start to rise. Few minutes later,it lowers.... It did this a few times like someone was rising and lowering it. Now all of a sudden the volume goes all the way up and cant shut TV down by the switch, have to unplug it. Is my TV haunted????
    Scholar:
  • 136 Answers
The tact switches on the front of the unit are going bad, need to replace them internally.
Posted on Sep 15, 2007
Philips TV 42PFL7403D/F7 Remote no longer controls Volume & ON/OFF
you can start with opening the remote control and clean the buttons on your remote control. don't use any aceton based products. there can be some grease on the buttons.
if you used the on/off and volume more then the other buttons.
Dec 19, 2017 | Philips Televison & Video
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
I bought my Cuisinart Bread Maker in February 2007 and it worked well until now. Yesterday I started to make Dough cycle. First 2 minutes machine kneaded the dough correctly as usual but suddenly...
check the underside of the basket. I have had problems with the lock washer, causing the wing nut to slip and not providing any turn to the shaft and paddle.
Sep 22, 2010 | Cuisinart CBK-200 Bread Maker
Both of the remotes don't work. put in new
pull battery cables for a few minutes to reset ecm and remote signal receiver.
Oct 13, 2009 | Suzuki Aerio SX Cars & Trucks
Remote control
Try installing a pair of new alkaline batteries into the remote. If the problem persists, I would suspect the remote is defective and return it to the store for a refund. I have used Philips remotes twice before, and had problems with both of them. I switched to a One-for-All universal remote, and it has been trouble-free, so far.
Jul 05, 2008 | Philips 60P8341 60" Rear Projection...
Toshiba 32A35 32" TV Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
