Question about HP Color LaserJet 2600n Printer
Duplicate images through page?
Ex: a letterhead on top of page, is printing throughout the page, instead of just top, dulpicate images down the page?
  • Anonymous Apr 28, 2009
    When I print a colour document, the letter heading, or any graphics appear elsewhere on the page. A sort of 'ghosting' effect.
  • janimcdo May 06, 2009
    I have the same problem. Happens on all print jobs. Image/test repeated down one side of doc mor than once. I.e. on test page, HP and far left of image, about 1 cm thick, repeated down the left side of page 3 times. Cleaning helps slightly but doesn't last.
    Thank you for help. We are on an island in the north - service is iffy.
    Janice
  • 26 Answers
On all printjobs? sounds like bad toner cartridge
if the print out has rough or parts that can smudge real easy then it is the fuser
more likely the toner - cleaning blade not clearing old job before going onto the next part of the print job
Posted on Apr 16, 2009
How to write a letterhead to apply for an internship?
Normally a letterhead is a professionally printed blank sheet of paper with your name/address/logo/etc. pre-printed on the top. You could design your own letterhead using a word processing program to print as a header on your application letter. It seems pretty unusual to require a letterhead, especially for an internship. Perhaps they mean a letterhead from your university?
Aug 30, 2016 | Miscellaneous
When printing on letterhead, my documents have a slight "copy" of the letterhead in various locations throughout my document.
Your preprinted letterhead is sluffing off during the fusing process. Have your service tech adjust the fusing temperature.
Aug 12, 2014 | Brother MFC-8860DN Printer
SOMEBODY CAN WE HELP US? WE HAVE A PROBLEM WITH DUPLEX LEXMARK X644.
If you mean that you are getting a ghost image of the letterhead on the page this is caused by not setting the paper type to letter head which caused the temperature to be wrong and print does not bond. Or you may have a bad fuser or bad toner cartridge. Try setting the paper type to letterhead or bond first to see if that helps.
Aug 07, 2014 | Lexmark X644e All-In-One Laser Printer
HP LaserJet 1020 PATCHES ON PRINT OUT
if the patches are random, and not ghost images duplicating down the page, you may need to take out the toner and gently shake it - tilt it right 90 degrees, then left 90 degrees, etc a few times to redistribute the toner...
failing that, the toner could be almost empty.
otherwise, check and see if they are duplicating down the page.. ie the same image defect 3 or 4 times down the page, if so, it is probably one of the drums.. toner or fuser drum...
Hope this info helps.
May 15, 2012 | HP LaserJet 2550L Printer
My Canon MF4150 is printing fine but when it prints a page, the content on top get duplicated (faded) below.
If you're getting the image repeated further down the page, but faded, it's most likely a fuser problem. The rollers in the fuser (or the fuser itself) will need to be replaced.
Mar 09, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Spots on master
THE DRUM THAT MAKE THE COPIES IS DURTY OR HAS DRYED INK ON IT AND IT TAKES A SPECAL CLEANER, I CAN NOT EVEN SAY THE WORD OR EVEN SPELL IT FOR YOU
TRI ETHI LINE, CALL A COPY MACHINE COMPANY OF GO ON LINE TYPE IN MANIFACTURE NAME ONLY RETURN ,
THE CORRONA WIRES THAT MAKE THE ELECTRO STATIC IMAGING MAY ALSO NEED TO BE CLEANS, Q-TIP AND ALCOLHAL WITH A VERY SOFT HAND OR YOU WILL BRAKE THE WIRE AND THAN YOU WILL BE WITHOUT A COPIER
CANDYMANGANDY
Jan 29, 2009 | Riso RZ310 Duplicator
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
Won't print all of the letter on top of page
Hi afoot, that sounds like you need to adjust your printer by moving or adding more margian between the letterhead & the edge of the paper.
Best of luck to you!
Mike
Mar 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
307 people viewed this question
Seeker5211
Seeker5211
