Question about KDS Valiant 6380iPTD-01 Notebook
Honeywell 927 wireing to vaillant combi
The honeywell 927 wireing showes to go to t1 and t2 the vaillant wire diagram dont show t1 and t2 any
can you tell me waht the wires shoud go to on boiler
On the aquastat I have the white&blue wire on T1 the red on T2 and the green on Z or N my question is where do they go on the V8043 F 1036 ports?If you could help to the zone valve I would be Greatful
Need much more info but this sight might help you. Click on submittal sheet and keep scrolling until you find your schematic. Probably page 15 or 16.
www.supplyhouse.com/Honeywell/V8043F1036
Hope this helps a little.
Nov 20, 2017 | Heating & Cooling
I need help figuring out funky thermostat wiring on my 240v baseboard heaters.
sounds like your heater already has 120 going to it at all times. it doesn't heat because it needs 240. therefore your tstat breaks the black, when it calls for heat it closes the black therefore giving your heat the remaining 120 and begins to heat. I would think it would work just with the blacks going to l1 t1 but if l2 t2 needs the jumper you are not doing any harm. who knows what goes on inside your walls but if it ain't broke don't fix it
Oct 30, 2017 | Honeywell Heating & Cooling
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
At electrical connection, from 120 ac on, off switch which remote controll connection terminial ...T1 or T2 does the black hot wire and the white neutral wire connect to ???? manuel does not show
On this unit it does not matter because it is a restive load usually I would go black t1 and white t2 it should be L1 and N always unplug before working on it
Dec 01, 2013 | Rinnai 7.5 Gpm Gas Tankless Water Heater -...
Replacing double pole 220 v with honewell ct410a two wire120/140v wiring diagram not clear
1 power wire (120v) will go to the thermostat and 1 power wire (120v) will go directly to the unit. The other wire on the unit will go to the other side of the thermostat. The safety precaution behind using a single pole to replace a double pole contactor is that you will always have 1 leg of power going to the unit. Many systems are designed like this from the factory, but it is always better to have a 2 pole to cut all power off to the unit unless it's in operation. The unit will still not work as long as it does not have both legs of power.
L1 to Thermostat T1 to Unit
L2 and T2 wired together.
This is only for 240v systems. 120v Will have 1 common and 1 power, therefore you will need to know which wire is which. Power to thermostat, common wired direct.
Nov 26, 2013 | Honeywell Programmable Thermostat Heater
Where do the wires from the compressure go to on main base
Wiring up a compressor
The Start wire goes to one side of the run capacitor it will be the only wire on that side of the capacitor.
The Run wire goes to the terminal side (T1 or T2) of the contactor, it will have another
wire from that terminal to the run capacitor which is the opposite side of the start wire.
The Common wire will go to the other side of the contactor (T1 or T2).
Start Kit
Start from the capacitor to terminal #1 on start relay There should be another wire from
here to start on the compressor.
Common from contactor ( T1 or T2) to terminal #5 on start relay. There should be a wire from this terminal to the Common terminal on the compressor.(there will not be a capacitor in this circuit)
Run from the other side of the contactor ( T1 or T2) to the start capacitor and from the other
Side of the start capacitor to terminal #2 on the start relay. There should also be a wire from this
Terminal to Run on the compressor.
Jan 14, 2010 | Heating & Cooling
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Need to wire honeywell programable stat to a valliant boiler
need more info about your system is your stat heating only if yes r and w on stat go to two wires at the boiler T1 and T2. You may have some other controls and would have to list them all.
Nov 06, 2008 | Heating & Cooling
KDS Valiant 6380iPTD-01 Notebook Logo
224 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
