Boot up problem
Hi
I have a FUJITSU PI 1536 with a boot up problem, this machine as been working flawless up until about a week ago, then all of a sudden i have to keep pressing the on off power button to try and boot up, sometimes it could be half an hour pressing the button sometimes 10 mins, the led lights come on for a few seconds then go off no beeps, hard drive does not boot and a blank screen, if i keep turning on and off eventually the laptop boots up and loads with no problems, and it will run as long as i have it turned on, but when i turn it off i have the same problem again, i have removed the battery and the hard drive to try and boot to no avail same problem, any help or advice would be greatly appreciated.
I am running windows xp home add with 1gb memory, thanking you in advance.
Regards
Kev
  • wilcokl Apr 15, 2009
    Hi Guru
    Thanks for the quick response, this is weird i have just dowloaded the diagnostics for my Fujitsu hard drive run diagnostics, and the result was no hard drive recognised, also in recovery console hard drive not recognised, yey i have the laptop on atthe moment booted up in windows, gone to my C drive which is showing my programes and properies, i do not undertand this help!!!!
    Regards
    Kev
  • 432 Answers
Back up your data from the hard drive and then use your xp disc and go into recovery console and run
chkdsk /r
and fixboot and fixmbr and try again.
Also if you find out the manufacturer of the hard drive and go to there website you should be able to get diagnostic utils to test your hard drive.
Also if you go to www.memtest86.org you should be able to burn an iso disc to boot from to test your memory.
Posted on Apr 15, 2009
  • Shane Russell
    Shane Russell Apr 15, 2009
    I would go to start --> run and type cmd and click on ok
    Then in the command prompt window type
    chkdsk /r
    it will prompt you or should do and say it cant do it properly and do you want to run chkdsk on reboot press the y key / letter and press enter and reboot and it should run the chkdsk when windows manages to reload
    Is it a sata drive as it may not be loading the sata drivers when trying to boot the cd or when going into recovery console so you may have to get the sata drivers onto a memory stick or floppy disc or slipstream the sata drivers into the hitachi disc ( might be able to use nlite to do this )
Will not boot up
Did your device come with any PC software? If so try connecting it to your computer and see what happens
Nov 13, 2013 | Lowrance iWAY 600C Car GPS Receiver
Hi I have a fujitsu amilo pi 1536 laptop and wish to return it back to factory settings. All i have is the laptop and no recovery disks etc. I've tried pressing F8 which brings up the windows advanced...
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Aug 02, 2011 | Fujitsu AMILO PC Laptops
Fujitsu N6420 upgraded to Windows 7 Professional. Ran fine for a month or so until it hung in middle of automatic Windows update. Now can not boot from hard drive or CD--gets to Windows logo splash screen...
If you still have the install disk you can put that in, hold F12 as the computer is booting up, and choose to boot from CD. The setup disk has a repair option that might fix the problem.
Apr 06, 2011 | Fujitsu LifeBook N6420 Notebook
Hello, I have an Amilo pi 1536 and suddenly all my network adapters stopped working. Windows displays error 31 in all of them.
Use an another laptop /pc and download the appropriate drivers from the fujitsu siemens website and then re-install them. possibly corrupt files at the registry?.....
let me know how you get on!
Mar 19, 2011 | Fujitsu Computers & Internet
Chiedo cortesemente come accedere alla batteria tampone x resettare password di bios . grazie anticipatamente
To reset the BIOS password read the information from this link. In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Per reimpostare la password del BIOS di leggere le informazioni da questo link. In caso di computer portatile il metodo pi? semplice sarebbe utilizzando il software da Hiren's Boot CD.
Jan 07, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Jan 16, 2010 | Fujitsu AMILO PC Laptops
Mac Pro not booting - blue screen
This symptom can signify one of the following things. 1) Mac OS is corrupted and needs to be re-installed."Archive & Install" 2) You hard drive is rendered unbootable, Erase & Install may work. 3) Hard drive needs replacement
Oct 01, 2009 | Apple Computers & Internet
Juice on pi-1536 keyboard and touchpad
Juice on keyboard ?? Disconnect ALL power immediately!! Then, remove keyboard, run under quite hot tap water, then immediatey submerge keyboard in isopropyl alcohol in a shallow tray, place in a beach towel & with washing machine water OFF, spin the unit in towel, allow 24 hrs to dry in sun, reinstall. It works.... If LAPTOP got drenched, stand on side, with screen open, dry thoroughly 2 days, pray a lot,
Jun 21, 2009 | Fujitsu Siemens Computers & Internet
Password when I start up my Fujitsu Siemens Amilo Pi 1536
hi astrid
can u please explain is the password on bios
Jan 07, 2009 | Computers & Internet
926 how to print black ink with economical settings
this machine worked fine until today.there is plenty of ink in the cartridges,just replaced the black one a week ago ,worked fine till today when i tried to use it .p.c. works fine,im pi----.
Oct 23, 2008 | Dell 926 All-In-One InkJet Printer
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
