Question about Freezers
4 wires unplugged behind freezer, - Freezers
  • 3 more comments
  • mikemeyers Apr 15, 2009
    need to know how to plug back in
    different color wires
    NEED DIAGRAM
    2 Black, 1 Red, 1White
    Need Diagram
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 24, 2010
I wish to remove the Door. How do I disconnect the wiring Harness from door to freezer?
unplug from the outlet before this,,open the door,unscrew from behind the door seal,take off the plastic inside door,then unplug everything and then unbolt the hinges
Apr 29, 2015 | Freezers
Why do I have ice in the bottom of a whirlpool EV205nxtn upright freezer?
My name s Peter. I am a retired field service technician.
1.) First, lets check your defrost timer. You will need a small flat head screw driver. Pull your freezer out to where you can get behind it. Do not unplug your freezer yet. There is a small white box almost 2" square. On this box is a small shaft with a slot in it. Turn this dial with your screw driver slowly until your unit shuts down (Compressor not running). What you have just done is force your unit into the defrost mode.
If the unit does not shut down you have a bad defrost timer. We are not done with the defrost timer yet.
Take a break, grab a cup of coffee, allow the unit 30 minutes to defrost.
Upon returning if the freezer has defrosted you have a bad defrost timer. Unplug the freezer and replace. Easy job.
2.) Ok, not the timer. Lets check the freezer drain. At times the freezer drain freezes up. When the unit goes into defrost the condensate can not go down the drain and you build up a wall of ice behind the bottom back wall.
Unplug the freezer. Pop the setting control knob off on the lower back panel. You may need a screw driver to wedge it off. Pull the seal strips out on the 2 sides. Unscrew all of the fasteners on the back panel cover. You can not remove the cover yet. You must disconnect the temperature control. There are different mountings. Perhaps 2 screws holding the control to the back cover or a connector where you need a small screw driver to wedge them apart.
Ok, you observe a wall of ice and have a frozen drain. Do not let the freezer defrost itself, you will have a flood. Using a hair dryer and a plastic spatula melt the ice and remove it in chunks. This is a long consuming task, take you time. Be careful not to touch any of the unit components. Let the hair dryer do the work on the evaporator coil etc. Clear the drain with hot water soak up as much as you can. We do not want this to happen again - lets make a heat sink. Taking a piece of 12-14 gauge wire about 3' long, strip about 2" off one end. You should wear gloves. The fins on the evaporator coil are razor sharp. Wrap the striped end of the wire around the defrost heater (Long black bar beneath the evaporator coil). Secure it tightly. Extend the other end of the wire to your drain hole. You want to cut the wire where you strip 2" of exposed bare wire into the drain hole. So, when your defrost heater is on any ice in the drain hole will be melted. Reassemble the back panel. Plug the unit in.
I can not finish. I am limited to size of response
Oct 19, 2014 | Freezers
My freezer is cooling but it is running too much. I was trying to find a new gasket for it. The model number is MCCF5WBX. Is there anywhere that I can find one?
On all freezers there is an area either below or behind that resembles an automobile RADIATOR....this can become clogged with dust. Try unplugging and moving the appliance away from the wall and accessing either behind or beneath and vacuum-out all dust and debris. Replug or restart the freezer, plugging it in, and see if there is a difference. These types of refridgeration devices require the clear passage of air, circulating thru the cooling filters inside and outside of the freezer. Always have air-circulating around your freezers and fridge.
Oct 08, 2010 | Magic Chef Chest Freezer MCCF5WBX
Thanks, I bought a woods freezer modelco7na-k1 3.0amps, ok my question is it got into a flood and now makes ket ket noise when pluged to the eclectricty but does not get cool
The issue is most likely the relay that starts the compressor.
Behind the freezer on the bottom is a black device about the size of a bowling ball, this is the compressor. Mounted on the side of the compressor in a box with wires going in is the relay. Unplug the power cord to the freezer. Pry open the box and note what wires go where. Remove the wires and pull off the components from the compressor, they may be tight but will pull off. You should be able to find this at a local appliance parts dealer.
May 11, 2010 | Woods Upright Freezer MU07W
Freezer runs but does not cool
have you tried to replace the fan motor located behind the panel, just remove the 4 screws in each corner and the fan is behind this panel, it should be 2 screws and a few wires to disconnect, replace motor and connect wires this should cool the freezer properly
Oct 17, 2009 | GE Freezers
Ice keeps melting in the freezer side of the fridge periodically and leeking water everywhere. Temperature seems to randomly drop to the point where it melts.
Sounds like it's the defrost thermostat gone bad. It's located on the evaporator coils behind the back cover inside the freezer. It may be mishapenned or you can test it. It should show continuity with an ohm meter when it's above 35 degrees. It cuts the defrost heater off to prevent overheating.
Jul 08, 2009 | Freezers
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
When plugged, kenmore freezer shorts the surge protector and outl
if thats the case should be an apparent wire off, somethings shorting directly to ground. the chest freezer has all of its wiring behind the access panel on the side of unit , no other wires in machine id look right there for something obvious
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Burning Smell
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Jan 12, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezers Logo
43 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
