Question about Apple iPod mini M9160LL/A MP3 Player
My mini ipod freezing, showing charger sign i could not turn it to menu
Hello! my mini ipod freezing, when i turn it on, the apple sign appear, after the apple sign disappear then the charger sign shows and i could not turn it on to menu, its freezing, i tried to connect via usb to my laptop and its not detecting.. how to solve this problem? could anyone can help me? TIA!
  • 5 more comments
  • Madmama Nov 11, 2007
    Actually it has now gone completely blank, after the inability ti connect to PC and not holding a charge for more than 2 hours.Now, it will not charge at all or come on any longer. This was never used often and never dropped. I have had it plugged into the wall charger for 3 hours and it isn't turning on or getting warm.
  • ghty Nov 25, 2007
    it doesn't turn on at all
  • rangers-mich Jul 29, 2008
    My Ipod Mini will not turn on at all.. when i connect it 2 my computer the apple logo appears then goes away then the battery logo appears.. but after a few hours when i disconnect my ipod it still does not turn on..!
    HELP
  • Anonymous Mar 27, 2014
    After listening to a couple of songs, the iPod Nano freezes into the apple logo/sign and the background is pink. What is happening?
    Why does my iPod Nano freeze after listening to a couple of songs, and the background is pink and the apple logo/sign shows up.
    Why after listening to a couple of songs my iPod freezes into a pink background and the apple logo/sign.
  • Anonymous Mar 28, 2014
    My iPod only turns on till the apple shows and never completely turns on
  • 150 Answers
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Posted on Sep 14, 2007
My mini ipod freezing, when i turn it on, the apple sign appear, after the apple sign disappear then the charger sign shows and i could not turn it on to menu, its freezing, i tried to connect via usb to my laptop and its not detecting.. how to solve this problem?...
Posted on Oct 09, 2008
3 Suggested Answers
SOURCE: mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Posted on Feb 18, 2008
frithangelo
  • 21 Answers
SOURCE: my mini ipod freezing, showing charger sign i could not turn it to menu
try to plug it on the socket wall and charge it for about 2 to 3 hours and connect it to your pc it works
Posted on Apr 27, 2009
How do I reset an ipod mini 4G?
To reset iPod mini:
1. Toggle the Hold switch on and off (set it to Hold, then turn it off again).
2. Press and hold the Select and Menu buttons for at least 6 seconds, until the Apple logo appears.
Download Apple iPod Mini Manual
Aug 21, 2014 | Apple Mini IPod
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Ipod shows the help screen with a website
Try thisout and restore th ipod
Feb 08, 2009 | Apple iPod MA446LL/A MP3 Player
Ipodnano8GB connection
you have to restart your iPod. press the middle/center button and the menu button for a few minutes
Jan 01, 2009 | Apple iPod nano
IPod Freezes
Have you tried to reset it, by holding down both the menu and center button until the apple sign appears? My Nano freezes and then it does I just reset it.
Sep 19, 2008 | Apple iPod nano
Ipod freeze how do I restart
This method is to restart your ipod without erasing any of your saved things.
1. Check that your hold switch is off by sliding the switch away from the headphone jack. The hold switch is located in the top corner of the iPod. If you see orange, then the iPod is locked. To unlock the iPod, slide the switch in the opposite position.
2. Press and hold the following combination of buttons buttons simultaneously for approximately 10 seconds to reset the iPod.
For iPod 1G to 3G (scroll & touch wheel iPods): "Menu" and "Play/Pause"
For iPod 4G+ (includes Photo, Nano, Video, and Mini): "Menu" and "Select Center Button"
For iPhone & iPod Touch: "Menu" and "Sleep Button"
For Shuffle: Turn it off. Turn it on. Done.
If you have an iPod Mini or 4th gen iPod or higher, then you need to press the Menu and Select buttons. The Select button is the center button in the middle of the wheel. For older iPods (1G - 3G) you'll need to press the Menu and Play buttons to restart.
Upon reset, your will see the iPod/iPhone name and the Apple logo. When this happens, you can let go - the iPhone/iPod is rebooting. If your battery is very low, you may have to attach your iPod/iPhone to a power source.
3. The iPod name and the Apple logo will briefly appear upon a successful restart before advancing to the Main Menu.
4. If you have your iPod/iPhone connected to your computer and iTunes open, then your iPod/iPhone should mount and show up under "Devices" in the left iTunes sidebar.
May 05, 2008 | Audio Players & Recorders
Ipod mini screen freezing
How to manually reset a frozen iPod mini:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, which takes about 6 to 8 seconds.
http://docs.info.apple.com/article.html?artnum=61705
Feb 26, 2008 | Apple iPod mini M9160LL/A MP3 Player
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Mini ipod freezing showing charger sign
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
421 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
