Question about Garmin nuvi 205 GPS Receiver
Did I lose my map?
I registered my nuvi205, and "thought" I was updating my maps...but now it shows a start-up message that "No detailed maps found that support routing. The nuvi cannot be used without them." It was working fine before I attempted the registration and update. I can't figure out what happened or how/where to re-install the old map.
  • 3 more comments
  • locmradio Apr 15, 2009
    Join the club. Sounds like a lot of us are in the same boat with the same exact problem.
  • Dbl-dia Apr 18, 2009
    Eaxctly same problem, wummm
  • Anonymous Apr 19, 2009
    I get the message "No detailed maps found that support routing. The nuvi cannot be used without them." The GPS was purchased in late August 2008 and this is my first problem with it. Can't figure out what happend to cause this.
  • Anonymous Apr 20, 2009
    same thing...
  • nks6 Apr 20, 2009
    I have the same problem... brand new GPS & had no trouble until the
    map download. I called Garmin & spent over 4 hours on hold before
    reaching a support person. In talking with Tech Support & a few
    emails later this is what I learned: "
    Thank you for contacting Garmin International.
    We spoke earlier today about your nüvi 205 and the map update. Since we
    spoke, I have learned new information about the issue you're
    experiencing. Apparently, the large part of it is a problem with part
    of the update. Interestingly enough, it only affects the nüvi 205
    models. Currently, the fix is in production and although they indicated
    to me that it should be resolved tomorrow sometime, you may want to wait
    until Thursday or Friday to attempt it because I'm not sure at what
    point tomorrow they will release the fix (barring any delays, of
    course). They indicated that to complete the fix, you must delete the
    original download file, empty your recycling bin, and then download the
    file once again. Although your attempts today may have been successful
    in downloading and running the update, I am told that even in these
    situations with the 205, you still receive the "Can't Unlock Maps" issue
    because of this larger problem. I'm incredibly sorry for the
    inconvenience as well as the fact that I was unaware of this at the time
    of our conversation. Please let me know if the re-download does not
    work when you attempt it after tomorrow. Thank you in advance for your
    continued patience."
    I have tried to redownload & install the file, which is a looks like it was already a second edition as it ends as 2010B. Seems they're still working on the update.
    Looks like we're all in the same boat for now until Garmin throws us a lifeline.
First you will want to empty your recycling bin & clear your temporary internet files before re-downloading the Garmin_RMU_2010B.exe file. Below is the remainder of the fix I received from Garmin support and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the end of setup.exe". For example the end would look like xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps. 9a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have any trouble with this fix, or are not comfortable trying it please call our Software Support Department at 1-800-800-1020. Please be at a computer that has high speed internet access as we may need to log on to your computer to resolve the issue. Make sure you have the program extracted using the 7 zip program provided above. Hours of Operation Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
Posted on Apr 28, 2009
I had the same problem, I was on hold with garmin and a software specialist told me to do the following before I update the maps.
Before running next map udpate. Besure to delete the gmapsupp.img file in the Garmin folder on the gps.
How do i reset my garmin nuvi 200w satnav it says no detailed maps found how can i reinstall them
Locate the reset button, located on the back of the device, in the lower left corner. Remove the sticker covering the button, and use a straightened paper clip to depress the tab.
To reinstall maps
Connect your Garmin Nuvi to your computer via USB cable. You can only update the maps through connecting to your computer.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
heres a link to the site;
http://my.garmin.com/mygarmin/login.htm.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
Close Garmin Express and unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
If you weren't automatically prompted to install Garmin Express, you can download it from
http://software.garmin.com/en-US/express.html.
Jun 06, 2015 | Garmin nuvi 200W GPS
Garmin nuvi
This is an indication that the map or map unlock key is either missing or corrupted. If you have registered your unit with Garmin, try connecting to your PC and try downloading the map again. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Sep 30, 2013 | Garmin nuvi 200 Car GPS Receiver
I used my new Garmin yesterday. My town is not even listed. I thought I would go on-line to register. AND, obviously, I wanted to get my 1 map update. When trying to do this I realized I do NOT have a...
Go on SETTINGS > MAP and choose there:
Map Detail = MOST
Orientation = 3 Dimensional
Metro Areas = Enabled
Show Location = On Roads
Map Features = choose ALL OF THEM to make any town/city visible.
Mar 06, 2011 | Garmin GPS
My nuvi205 lost all the maps
You lose the maps or they not chosen?
To see if they are still on your unit go to Tools.... Settings....Map.... on bottom of screen press Map Info
make sure there is a checkmark in City Navigator North American NT
Nov 07, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin will not bring up eny maps . It just brings up no detailed maps found that support routing.
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To register
· Connect the satnav to your computer.
· Go to www.garmin.com and select your country
· Click on “myGarmin”
· Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 16, 2010 | Garmin nuvi 350 GPS Receiver
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 200 says no detailed maps found where can I download a map
You may not need to download a map. It's possible that the map is there but not selected or that it's locked. I'll give you details first of how to solve this problem and then I'll give you details of how to get a new map. Your satnav must be registered with garmin to unlock the map or to download new maps. If it's not already registered you can register it at https://my.garmin.com/mygarmin/customers/myGarminHome.faces Click Register Your Garmin Product and follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them again anytime you want to update your satnav.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
To update the maps Log into my Garmin. Click on myMaps. If there's an update it will be shown there. Click on Get Update and follow the prompts. Maps are large Europe is approx 4Gb so you'll need broadband to download it. If you don't have broadband you can opt to get the update posted to you on DVD. You'll also need a credit card to pay for it.
Aug 08, 2010 | Garmin nuvi 200W GPS Receiver
PROBLEM UPDATING MAPS
Plug your GPS into your PC and do not use the Garmin Express program. It will mount as a drive. Delete the maps and software. Then run Garmin Express and do a complete install of the maps and software.
Apr 04, 2017 | Garmin nuvi 255W GPS Receiver
Nuvi 255, no maps intstalled, shows unlocked in detailed info
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Mar 20, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
532 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
